Error starting revit 2014
1 REPLY 1
1473 Views, 1 Reply
When trying to start the revit 2014 I get an error message which says you can not start the application, the parallel configuration is incorrect. Consult the event log or use the application sxstrace.exe tool command line for more details. I tried to launch with administrator rights and compatibility and the problem still persists, someone might know to be the problem?
Tags (4)
1 REPLY 1
fernanda.firman
Thank you for posting.
This issue have been addressed in the following links:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14095878&linkID=9241177
http://forums.codeguru.com/showthread.php?444448-quot-Side-by-side-configuration-is-incorrect-quot
It is showing under the 3ds max but this is a windows message, not specific to Revit.
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
