Hi fellas!
Is it possible to have a callout above the cut plane in any way?
Or edit the view range?
Want the callout the show a window above cut plane (shows in plan with filter)
Solved by Marcus.Isacsson. Go to Solution.
If your enlarged plan (callout) needs 1 view range but has an area that needs another cut plane elevation, use the Plan Region command in the Callout view.
See the following video:
https://www.youtube.com/watch?v=Y6CafsiOnsk
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
