Door family insertion problem
4 REPLIES 4
2277 Views, 4 Replies
I'm trying to insert a double door into an interior storefront butt glazed system. The door displays perfectly in the family form but when the family is inserted into the storefront the door pulls shift laterally about 4" from where they should be.
I've tried dimensioning the pulls in plan and/or elevation to the door edge and to the center reference plane, locking them, unlocking them, using a different template, etc.
I've used the same pulls as part of a door assembly that is inserted into a gypsum board assembly without any problem.
The pulls are not nested into the family.
Appreciate any help anyone cares to offer.
4 REPLIES 4
LisaDrago
Can you post the door family? Sometimes I need to think with my hands...Smiley Very Happy
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Thanks LD. File attached.
Alfredo_Medina
The pull handles are not the only problem. Notice what happens with the pivots:
It is recommended that you use nested families for these accessories, instead of extrusions and sweeps made in the same file. Nested items will give you reference planes that you can use to align and lock these nested items to reference planes in the host family.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
in reply to: Alfredo_Medina
Thanks much.
Tom Urie, R.A. LEED AP
Urie P.C. Architects
11114 Innsbrook Way
Ijamsville, MD 21754.9058
301.602.7606 (voice)
301.865.4784 (fax)
tom.urie@urieprocor.com
www.urieprocor.com
