Anyone know if it is possible to create proper dimensions for 3D isometric drafting views? In AutoCAD I could set an oblique angle for a dimension but in Revit there is no setting. I can only dimension 3D model views.
See attached PDF for example.
Ther is no oblique dimension style in Revit. You could do this kind of view as a 3d model view with elements hidden, a section box and the line work tool.
I thought so. Unfortunately if you want to reuse the detail across multiple project it means recreating it each time. 😞
The tip shown by Vector about changing the workplane to apply dimensions in 3D views is useful, but it does not apply to drafting views (the topic in this thread) since a drafting view is just a flat drawing with no workplanes.
In a drafting view, you can use the regular Aligned dimension tool to fully dimension the drafting view, even if it is an isometric kind of view. The only missing feature would be the "oblique" angle, but apart from that, you can dimension everything.
@Alfredo_Medina wrote:"drafting views (the topic in this thread)"
Are you saying if that drawing I posted on that Revit sheet came
from AutoCAD that it would not be a drafting view? (the topic of
this thread). Where does it have to come from to quality as a
drafting view? Remember they only asked for dimensions on
a drafting view.
@Anonymous wrote:"it's not feasible in a revit drafting view."
That's correct but they didn't say anything about doing
this in a revit drafting view.
Revit is different than AutoCAD and this is one the functionalily (oblique dimensions) which Revit doesn't have.
Not true. The original post in this thread begins with "Anyone know if it is possible to create proper dimensions for 3D isometric drafting views?"
A drafting view is flat, even if it shows a "3d" representation of an object. Therefore you cannot dimension that drafting view by setting workplanes because it is not possible to set a different workplane in a drafting view.
Is it still not possible to add oblique dimension in Revit Drafting Views?
Has there been any progress from the Revit team on making oblique angles for dimensions in a drafting view possible?
@Iev60047 wrote:Has there been any progress from the Revit team on making oblique angles for dimensions in a drafting view possible?
You won't get any word on that until it is released in a new version or update. You could try to join the beta testers so you can get insider information.
