Curtain Wall Mullions
5 REPLIES 5
DavidRaines
1106 Views, 5 Replies
I have been trying despertly to find a curtain wall or storefront in my system Revit 2015.  Absolute zero success.
First of all I have no curtain wall or storefront options in my browser.  So I tried curtain wall by using mass. When trying to place mullions on the face of the mass I am told there are no curtain wall mullions loaded and directs me to the imperial library. The only place i found curtain wall mullions was under profiles. I selected the mullion I wanted and now I get a new messate that states"  you cannot load one or more of these families. You must select a curtain wall family. (more or less)
hELP.
David
5 REPLIES 5
davidtetro
in reply to: DavidRaines
Can you upload your project?
SteveKStafford
in reply to: davidtetro
It sounds like your project has been subjected to Purge Unused. Open a new project using a stock Revit template, like default.rte or architectural.rte or defaultmetric.rte. The curtain wall types and mullions are present in those, at least a basic collection you can build on from there.
You can either create a few curtain wall types using the mullions you want, then copy/paste the entire wall from the project into yours or you can select a mullion family and right click Copy to Clipboard followed by using CTRL + V (paste) into the drawing window of your project. You should find the mullions are listed in your project's project browser after each time you do this.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
DavidRaines
It is a large file, and rejected. I have not tried zipping it. Do you have a
way for me to send you the file?
David
David Raines
907.229.3778
L.Maas
Upload your project to the cloud (e.g. WeTransfer, DropBox) and post the link, or send private message to the right person.
Louis
Please mention Revit version, especially when uploading Revit files.
davidtetro
David - I use Hightail and Dropbox. But, has the issue been resolved already? If so, no need to upload the file.
