Create extrusion in section view
2 REPLIES 2
mmostafaHKPP5
119 Views, 2 Replies
I simply want to create model in place. the best and easiest way is to draw an extrusion in a section view. I'm having hard time doing this. Can you please help?
2 REPLIES 2
You need to set a workplane (Architecture > Set > select a workplane) which could be a grid, a named reference plane, or the face of an object. Then you can draw the extrusion in the section view, perpendicular to the workplane.
syman2000
in reply to: mmostafaHKPP5
If you have gridline facing perpendicular to your section view, you can use grid as your reference. First you go to set and pick a plane. If you don't have gridline, then use reference plane.
Autodesk Customer Advisory Groups
