Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
possibly corrupt local models....did you try to delete them, support files and then make new local models to test?
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
if you open Windows Explorer and browse to your local revit model (usually within My Documents), you will see a support folder with the same name as the local model. Delete this folder as well prior to making a new local model.
two users have the same problem...everyone else is fine. Find the commonality between the two workstations that has the hiccup. It has to be hardware based if this is occurring on only 2 user's workstations. A complete deletion and rebuild of new local model from central should fix the issue normally.
try also, to temporarily NOT use View Template and see what happens. Can you see the Levels/Grids in other views with the 2 workstations? If so and the issue is on just a particular view, then delete the view and recreate it within the local model.
