Cannot Load Family Files
6 REPLIES 6
TOMASSANCHEZ5749
2345 Views, 6 Replies
I am not sure if I have done something wrong or what, but I am trying to load a Sidelight from the imperial library that came with Revit 2011 and I get a message stating the following.
" Some or all of the family files you selected cannot be loaded. You mush choose family files or the category Doors. Do you wnat to retry loading a new set of files?"
"Revit cannot load the following files: Sidelights 1.rfa"
Any suggestions?
6 REPLIES 6
Try dragging the file in Explorer into revit, it worked for me.
in reply to: TOMASSANCHEZ5749
side lights are actually windows.. hit the window tool first then load the side light..
brandon0403
I figured that out 20 minutes after i posted, but dragging removes the requirement that you have the correct tool selected.
I figured that out as well in about the same amount of time.  Thank you for your reply
TOMASSANCHEZ5749
I found that out. Thank you for your reply
each time a description of the change, there is always plenty to talk about around the world. they are not exempt. a statement usually are: "i have to change almost immediately versions, so do not expect me to date continue to attack .. watch winder
