I have created an A1 Titleblock for the office. Now i need the exact same at an A3 scale. When i select everything to scale it down, the scale tool fades out. Is there a way to do this, or do i have to recreate the titleblock all over again at A3 size?! Thanks in advance
I think that your problem is that the text is not scalable. I think you can scale the line work, but lables and text will have to be moved or changed to fit. Good luck.
Shawn Graham
Designer.
If i take the text out of the selection it still does not scale. I select only line work on the titleblock and it lets me scale but it doesnt stay that way, once i click to complete the scale, it refreshes and nothing changes. so i have to do this again manually for now.
