Hi Tony,
You requested my Revit.ini file, I did have it attached to my last email, here it is attached again. Perhaps I need to change all the drive mappings in the ini to UNC even though they are read correctly from the manual copy as I mentioned earlier.
Also:
[Revit.ini]
[Colors]
BackgroundColor=16777215
HiliteColor=12401408
PreHiliteColor=12401408
ErrorColor=33023
[Directories]
ProjectPath=D:\Revit Projects
ImportLineweightsNameDWG=J:\Projects\Data_Revit\RAC Resources\Utilities\2017\FBMimportlineweights-dwg.txt
MaterialLibraryFiles=..\Data\Rendering
IESFileLocation=C:\ProgramData\Autodesk\RVT 2017\IES\
LookupTableLocation=C:\ProgramData\Autodesk\RVT 2017\Lookup Tables\
ExportToClassIFC=..\..\..\ProgramData\Autodesk\RVT 2017\exportlayers-ifc-IAI.txt
RootPathForPointClouds=D:\Revit Projects\PointClouds
ExternalParameters=J:\Projects\Data_Revit\Shared Parameters\FBM Shared Parameter List.txt
[DirectoriesENU]
FamilyTemplatePath=..\..\..\ProgramData\Autodesk\RVT 2017\Family Templates\English_I
DataLibraryLocations=FBM Custom Library=J:\Projects\Data_Revit\FBM Library, Imperial Library=..\..\..\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial, Imperial Detail Library=..\..\..\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\Detail Items, Canadian Metric Library=..\..\..\ProgramData\Autodesk\RVT 2017\Libraries\Canada, Canadian Metric Detail Library=..\..\..\ProgramData\Autodesk\RVT 2017\Libraries\Canada\Detail Items, US Metric Library=..\..\..\ProgramData\Autodesk\RVT 2017\Libraries\US Metric, US Metric Detail Library=..\..\..\ProgramData\Autodesk\RVT 2017\Libraries\US Metric\Detail Items
DefaultTemplate=2017 FBM Imperial=J:\Projects\Data_Revit\FBM Library\FBM Custom Templates\2017 FBM Imperial.rte, 2017 FBM Metric=J:\Projects\Data_Revit\FBM Library\FBM Custom Templates\2017 FBM Metric.rte, 2017 DTIR Metric=J:\Projects\Data_Revit\FBM Library\FBM Custom Templates\2017 DTIR Metric.rte, Architectural Template=..\..\..\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\default.rte, Construction Template=..\..\..\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\Construction-Default.rte, Structural Template=..\..\..\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=..\..\..\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\Mechanical-Default.rte
[UserInterface]
DisplayRecentFilesPage=1
[Language]
Select=ENU
[Applications]
Mechanical=
Electrical=
Architectural=
Structural=
[InstallationSettings]
Language=ENU
Usage=All
[Install]
InstallGUID=
[ContentSearch]
Site=
http://seek.autodesk.com[Documentation]
HelpFileLocation=C:\Program Files\Autodesk\Revit Content 2017\Help\en-US\WBH\index.html
[DirectoriesCHS]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Chinese\
DataLibraryLocations=Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\Generic\
DefaultTemplate=构造样板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHS.rte, 建筑样板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHS.rte, 结构样板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHS.rte, 机械样板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHS.rte
[DirectoriesCHT]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Traditional Chinese\
DefaultTemplate=建構樣板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHT.rte, 建築樣板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHT.rte, 結構樣板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHT.rte, 機械樣板=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CHT.rte
[DirectoriesCSY]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Czech\
DefaultTemplate=Stavební šablona=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CSY.rte, Architektonická šablona=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CSY.rte, Konstrukční šablona=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CSY.rte, Mechanická šablona=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_CSY.rte
[DirectoriesDEU]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\German\
DefaultTemplate=Construction-Vorlage=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_DEU.rte, Architektur-Vorlage=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_DEU.rte, Ingenieurbau-Vorlage=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_DEU.rte, Gebäudetechnik-Vorlage=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_DEU.rte
[DirectoriesESP]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Spanish\
DefaultTemplate=Plantilla de construcción=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ESP.rte, Plantilla arquitectónica=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ESP.rte, Plantilla estructural=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ESP.rte, Plantilla mecánica=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ESP.rte
[DirectoriesFRA]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\French\
DefaultTemplate=Gabarit de construction=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_FRA.rte, Gabarit architectural=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_FRA.rte, Gabarit de structure=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_FRA.rte, Gabarit de génie climatique=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_FRA.rte
[DirectoriesITA]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Italian\
DefaultTemplate=Modello di costruzione=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ITA.rte, Modello architettonico=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ITA.rte, Modello strutturale=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ITA.rte, Modello meccanico=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_ITA.rte
[DirectoriesJPN]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Japanese\
DefaultTemplate=建設テンプレート=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_JPN.rte, 建築テンプレート=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_JPN.rte, 構造テンプレート=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_JPN.rte, 機械テンプレート=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_JPN.rte
[DirectoriesKOR]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Korean\
DefaultTemplate=시공 템플릿=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_KOR.rte, 건축 템플릿=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_KOR.rte, 구조 템플릿=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_KOR.rte, 기계 템플릿=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_KOR.rte
[DirectoriesPLK]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Polish\
DefaultTemplate=Szablon konstrukcji=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PLK.rte, Szablon architektoniczny=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PLK.rte, Szablon konstrukcyjny=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PLK.rte, Szablon mechaniczny=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PLK.rte
[DirectoriesPTB]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Portuguese\
DefaultTemplate=Modelo de construção=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PTB.rte, Modelo de arquitetura=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PTB.rte, Modelo estrutural=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PTB.rte, Modelo mecânico=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_PTB.rte
[DirectoriesRUS]
FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2017\Family Templates\Russian\
DefaultTemplate=Шаблон строительства=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_RUS.rte, Архитектурный шаблон=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_RUS.rte, Шаблон несущей конструкции=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_RUS.rte, Шаблон механического оборудования=C:\ProgramData\Autodesk\RVT 2017\Templates\Generic\Default_M_RUS.rte
[Backups]
SaveReminderMinutes=30
[Graphics]
TempDimFontSizeInPoints=12
AllowNavigationDuringRedraw=1
UseGpuOcclusionCulling=0
Antialiasing=1
AntialiasingOptions=1
SemiTransparent=1
ThinLinesEnabled=0
[Partitions]
Username=
WorksharingDisplayFrequency=5
[AppFrame]
Theme=1
[Windows]
Maximized=0
[ACMSettings]
ACMOnNetwork=1
ACMNetworkPort=14931
[Misc]
SSOServer=0
[Recent File List]
File1=
File2=
File3=
File4=
File5=
File6=
[Recent Workset List]
Config1=All
Config2=All
Config3=All
Config4=All
Config5=All
Config6=All
________________________________
Carl Hicks Revit ICE, Dipl Arch Design & Drafting
BIM Manager, Arch. Technologist
Fowler Bauld & Mitchell Ltd. Architecture & Interior Design
HS1-1660 Hollis Street, Halifax NS B3J 1V7
PO Box 514, Halifax NS B3J 2R7
Canada
tel: 902.429.4100 x 118
fax: 902.423.3063
[email protected] | send me files
disclaimer
