Type Parametres from systemfamilies
Hi
Hope some one can help me to get type parameters from a system family
I can get the instants like Area & Volume, but not eg. Keynote
With compoment families do I use eg Door.Symbol.get_Parameter(BuiltInParameter.KEYNOTE_PARAM);
But I can't get it to work with system families like floors.
Where do I fail ?? 🙂
FilteredElementCollector FMFloorCollector = new FilteredElementCollector(OpenDoc);
FMFloorCollector.OfClass(typeof(Floor));
foreach (Floor FMFloor in FMFloorCollector)
Floor_Keynote = FMFloor.get_Parameter(BuiltInParameter.KEYNOTE_PARAM);
Floor_Family = FMFloor.get_Parameter(BuiltInParameter.ALL_MODEL_FAMILY_NAME);
Floor_Mark = FMFloor.get_Parameter(BuiltInParameter.ALL_MODEL_MARK);
Floor_Type = FMFloor.get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME);
Floor_Description = FMFloor.get_Parameter(BuiltInParameter.ALL_MODEL_DESCRIPTION);
Floor_Area = FMFloor.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED);
Floor_Volume = FMFloor.get_Parameter(BuiltInParameter.HOST_VOLUME_COMPUTED);
jeremytammik
Dear Anders,
Thank you for your query.
I have no idea what you are doing wrong.
However, I can certainly tell you how to do it right:
Simply download the built-in parameter checker and see how it is done there:
It is available from the BipChecker GitHub repository:
https://github.com/jeremytammik/BipChecker
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi
I tried, but Microsoft Visual Studio Express 2013, will not open the BipChecker.csproj file
I tried to run the addin in Revit 2016 (via the Add-in Managere (Manual mode), if that makes a diffirent 🙂
And got this message:
System.MissingMethodException: Method not found:
' Autodesk.Revit.DB.Element.get_parameter(System.AString)'.
at eseebase_AutoData.sharedParameterLoad.Execute(ExternalCommandDataCommandData, String& Message, elementSet elements) at AddinManager.AIMRunActtiveCommand(ExternalCommandData data, String& message, ElementSet elements)
Does that give you any ideas ? 🙂
Anders
jeremytammik
Dear Anders,
How you run it should make no difference.
The get_Parameter method is obsolete.
It is actually an auto-generated wrapper for the Parameter property.
It has been replaced by the GetParameter method, which now no longer is a property.
Are you sure you are using the most up-to-date version?
Probably not.
Check here:
The latest version is
https://github.com/jeremytammik/BipChecker/releases/tag/2016.0.0.0
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Anders,
It looks like you are trying to get information from instances of a floor. You are not having trouble with instance-based parameters, but you can't get type-based parameters. I would suggest that you find each instance, get the instance-based information, then find the type and get the type-based information.
I would suggest this:
	//instance params
	Parameter Floor_Family = FMFloor.get_Parameter(BuiltInParameter.ALL_MODEL_FAMILY_NAME);
	Parameter Floor_Mark = FMFloor.get_Parameter(BuiltInParameter.ALL_MODEL_MARK);
	Parameter Floor_Type = FMFloor.get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME);
	Parameter Floor_Area = FMFloor.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED);
	Parameter Floor_Volume = FMFloor.get_Parameter(BuiltInParameter.HOST_VOLUME_COMPUTED);
	Element el = FMFloor as Element;
	ElementId typeid = el.GetTypeId();
	Element floortype = OpenDoc.GetElement(typeid);
	//type params
	Parameter Floor_Keynote = floortype.get_Parameter(BuiltInParameter.KEYNOTE_PARAM);
	Parameter Floor_Description = floortype.get_Parameter(BuiltInParameter.ALL_MODEL_DESCRIPTION);
Note that get_Parameter(string) is obsolete, but get_Parameter(BuiltInParameter) still works.
Hi
That worked
Thanks a lot 🙂
Regards
Anders
