Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
convert to survey points
2 REPLIES 2
sanjaymann
255 Views, 2 Replies
What is the formula to convert  revit points to survey points. The problem is that when I am exporting a sheet to dwg revit is not taking survey points;inspite of me telling revit to use shared coordinates in the export procedure . Before members jump to conclusions I am doing this via code.
Thanks & Regards
Sanjay Pandey
2 REPLIES 2
mikako_harada
in reply to: sanjaymann
Hi Sanjay,
Could you try looking under
ProjectLocation >> < Internal nnnn >  >> Transform >> Origin?
I did some digging using Revit Lookup tool.  That value seems to indicate the location of Survey Point.
Mikako Harada
Developer Technical Services
sanjaymann
in reply to: mikako_harada
Thanks Will surely try this.
Rail Community
