Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
[Plugin Installer] How to get the installation folder of Revit ?
8 REPLIES 8
Message 1 of 9
2283 Views, 8 Replies
Hi everyone,
All is in the title. I've finished my plugin and would like to deploy it on the web as a single installer. And I need to add some dll in the Revit install foler. How can I do that ?
Thank you for your time,
Ngoc-Trang.
8 REPLIES 8
Message 2 of 9
Registration of add-ins
Check out "Getting Started with the Revit API"  attached from SDK
thanks
Message 3 of 9
Hi  baburajan,
Thank you for your answer, but I've already read this document and it seems that you've misunderstood my question. I don't ask for the folder to add my .addin file.
But anyway, I found another solution that don't require the installation folder of Revit.
Message 4 of 9
Hi, ngoc.trang
I have the same problem as you where i have completed my plugin and i need to package it as an installer. However, during debugging my plug-in with revit api, we need to add reference to two revit dll which is RevitAPI.dll.dll and RevitAPIUI.dll where this two dll is located in Revit installatiion folder. But now i need to package the plug-in as an installer, how do i reference back this two dll, by the way, what is the copyright for it? Many thanks if you can help me on this.
Message 5 of 9
Hi bsyap,
You don't need to copy the Revit .dll in your installer because it is supposed that they are already present in the computers, on which you install you plug-in ^^ (in their Revit install folder)
Hope it helps,
Ngoc-Trang.
Message 6 of 9
Hi, ngoc.trang
Thanks for the quick reply. Smiley Happy I am using Revit API SDK to create my first plug-in for Revit. During debug the program, i have to add reference to two revit dll which is RevitAPI.dll and RevitAPIUI.dll where this two dll are located in my personal computer's Revit installation folder(C:\Program Files\Autodesk\Revit Architecture 2011\Program\RevitAPI.dll)  and the dll  Copy Local property is set to false(which means this will not package to the release of the plug-in). But now when i try to package this add-in as an installer, how does end user computer can run my plug-in since they do not have this two dll in their computer?
May i ask
1)Do you package the Revit.dll into your plugin as well?
2)How you reference back this two dll?
Message 7 of 9
As I say before :
1) no need. Copy Local to false is right.
2) It is automatic if the target pc has installed Revit.
Message 8 of 9
Hi Ngoc Trang,
Ok I got it. How do you end up doing it?
Message 9 of 9
Hi baburajan,
At the first launch of my add-in, I can get revit install folder with :
Path.GetDirectoryName(Application.ExecutablePath);
I copy what I want there.
For a proper use, all I need then is to register this path to a config file, and at the unisntall I can remove my *.dll from Revit folder.
I don't know if it is the best way but it avoid me doing it from the install application.
Forma Design Contest
Rail Community
