Hi everyone,
My question concerns using the Revit API to open .rvt files from outside of Revit.
After reading through much of the documentation and examples, I see that I can do much of what I need, but only through ExternalCommand and ExternalApplication interfaces, both of which involve running Revit directly.
Is it possible to make a Windows Forms application to open a .rvt file, do some work, and exit, without creating external commands or ribbon buttons (a plug-in basically)? For example, I would like to open a .rvt file, retrieve all element names in some model, and write them to another file. I've managed to do this using the IExternalCommand Interface, but I don't want to have to open revit or create new ribbon buttons to do so. Is this possible? Or do all functionalities have to be within some type of Add-in?
Any information or advice is greatly appreciated. Thanks!
-- Joseph
Solved by mikako_harada. Go to Solution.
Solved by ollikat. Go to Solution.
Hi all,
Same as Joseph, I am interested in whether we can open revit file without opening the Revit.
Is there any updated information now?
John
Unfortunately, it is not supported, yet.
Hi Mikako,
I too am interested in opening revit files externally. You mentioned it was not possible "yet", and this was over a year ago, can I ask if it is possible now?
I can't find it anywhere in the documentation so I assume not, if this is the case can you confirm if this is in your development roadmap?
thanks,
Rob
Hi Rob,
Sorry, not yet. Still stays as highly demanded feature. I'm quite sure that if it becomes available, it will be a big topic on Jeremy's blog 🙂 So please keep eyes on his blog.
Although we cannot really support such a usage, some "desperate" developer seems to have tried using a joural file conjunction with idling event to runa a command, etc. Depending on what you want to do, you *may* be able to start Revit this way. Again, I cannot guaranty such a usage. But you may try with your risk.
Sorry for not being much help on this.
Any updates on this feature?
In one of requirement, I need to generate this files through some automated process so that users can use those file further for modifications, but they get the basic information in the file.
Please let me know if this is possible or is there a workaround.
thanks,
Kapil
Hi Kapil,
Sorry, no. But technology has evolved since the time we discussed this. We are working on cloud version. We are expecting to have Design Automation API for Revit. Using this, you can run Revit from your application on the cloud. You can find more info. from the following AU and DevDays Online presentations:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/classes/year-2017/revit/sd125457
DevDays Online 2017: Revit API updates
https://www.youtube.com/watch?v=w1WskGTzX3s
Timing wise, personally I'm holding my breath, while eagerly awaiting.
More info. in the video if you want to be a part of private beta.
Is there any update on this.
We have to read the elements and spaces from a Revit Model using API from an external .Net application.
Bimal George
