Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to Set Line Pattern in Line Style
10 REPLIES 10
Message 1 of 11
8147 Views, 10 Replies
I'm creating new line styles in Revit MEP 2013 through the API in VB.Net, and I've almost got everything figured out... except setting the line pattern. There doesn't seem to be a way to do this one, last step. Any ideas?
Here's what I have so far:
PublicFunction LoadStyle(ByVal n AsInteger) AsBoolean
Dim lineCat As Categories = m_RvtDoc.Settings.Categories
ForEach objCategory As Category In lineCat
If objCategory.Name = "Lines"Then
If objCategory.CanAddSubcategory = TrueThen
Try
Dim cat As Category = lineCat.NewSubcategory(objCategory, MEP(n, 6))
'set color
If MEP(n, 7) <> ""Then
Dim r, g, b AsInteger
                            r = MEP(n, 7)
                            g = MEP(n, 8)
                            b = MEP(n, 9)
Dim c As Autodesk.Revit.DB.Color = New Autodesk.Revit.DB.Color(r, g, b)
                            cat.LineColor = c
EndIf
'set lineweight
If MEP(n, 11) <> ""Then
                            cat.SetLineWeight(
CInt(MEP(n, 11)), GraphicsStyleType.Projection)
EndIf
'set line pattern
If MEP(n, 10) <> ""Then
'cat.LinePatternId = GetElementByName(GetType(LinePatternElement), MEP(n, 10))
EndIf
Catch
                        MsgBox(
"Line style " & MEP(n, 6) & " already exists.", MsgBoxStyle.Information, "Load Systems Error")
EndTry
Exit For
Else
                    MsgBox(
"Can't add line style.")
Exit For
EndIf
EndIf
Next
EndFunction
10 REPLIES 10
Message 2 of 11
Joe.Ye
Revit didn't expose the API to change category's line pattern. Revit engineering team already knew this request. Hope this will come not long.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Message 3 of 11
in reply to: Joe.Ye
Thanks for the response, Joe. Would it be possible to check to see if it's exposed in Revit 2014? And are there any workarounds? This is very important for my project.
Dave Horger
Interface Engineering, Inc.
Message 4 of 11
Joe.Ye
Thanks for your comments on the API wish. I passed on your comments on this request to the engineering team.
Joe Ye
Contractor
Message 5 of 11
atiefenbach
in reply to: Joe.Ye
+1 to adding this feature!
Anthony Tiefenbach
BIM Manager
HuntonBrady Architects
Message 6 of 11
jdbreazeale
in reply to: atiefenbach
+1 Please add this feature
Message 7 of 11
boostyourbim
in reply to: jdbreazeale
Yes, please fill this gap Autodesk so we can set the line style's line pattern via the API
Message 8 of 11
Dear All,
I have added your comments to the Epic story, there is still plans to work on this, but still needs to be prioritzed agains all other requests.
Thank you very much for all your patience and collaboration.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Message 9 of 11
in reply to: rosalesduquej
Yes, please add this! Has it been done yet? How many more years?
Message 10 of 11
Revitalizer
Hey,
in Revit 2017 API, there is a new Category.SetLinePatternId method.
Seems that Autodesk provides a solution, finally.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 11 of 11
Ning_Zhou
in reply to: Revitalizer
but SetLinePatternId() doesn't work, SetLineWeight() works fine along w/ LineColor
subCat.SetLineWeight((int)cat.GetLineWeight(GraphicsStyleType.Projection), GraphicsStyleType.Projection); // works OK
subCat.LineColor = cat.LineColor; // works OK
subCat.SetLinePatternId(cat.GetLinePatternId(GraphicsStyleType.Projection), GraphicsStyleType.Projection); // doesn't work
Forma Design Contest
Rail Community
