Error loading a plugin
Hai,
we are using revit 2016 trail version and we try to create a external tool to create a line when we click the plugin. find the c#.Net code attached. we are getting the error "Revit could not complete the external command" please help us.
regards
suresh p
Yo need to create and start a database transaction before you attempt to modify the model in any way.
Revitalizer
same reason as here:
http://forums.autodesk.com/t5/revit-api/how-to-paint-a-wall/td-p/5927663
"Do you use a Transaction ?
[...] as far as I can see, changes to the Revit DB must be encapsulated in a Transaction, excepting when using the TransactionMode.Automatic attribute for an ExternalCommand."
In your small example, just change the TransactionMode flag to Automatic.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
