How to paint a wall?
Organon
Advisor Advisor
Organon
Hello.
I'm trying to paint a wall in Revit 2014. First I get the material and then the faces of the wall, but when I select the wall nothing happens. This is the code in Python:
def PaintFace(self):
        uidoc = self.ActiveUIDocument
        doc =  uidoc.Document
        collector = FilteredElementCollector(doc)
        materials = collector.WherePasses(ElementClassFilter(Material)).ToElements()
        for material in materials:
            if material.Name == 'Copper':
                matName = material
                break
        elRef = uidoc.Selection.PickObject(ObjectType.Element)
        wall = doc.GetElement(elRef)
        geomElement = wall.get_Geometry(Options())
        for geomObject in geomElement:
            if geomObject == Solid:
                solid = geomObject
                for face in solid.Faces:
                    if doc.IsPainted(wall.Id, face) == False:
                        doc.Paint(wall.Id, face, matName.Id)
Any help is appreciated.
Regards.
Arquitectura | Análisis CAD & BIM | Diseño Paramétrico | Programación
BIM-METADATA | LinkedIn | YouTube
Revitalizer
Hi Organon,
the first that comes in mind is:
Do you use a Transaction ?
I'm not experienced in Python but as far as I can see, changes to the Revit DB must be encapsulated in a Transaction, excepting when using the TransactionMode.Automatic attribute for an ExternalCommand.
Second idea: have you checked if your material is not null ?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Organon
Revitalizer,
Yes, you are right; a Transaction is requiered. Rookie mistake.
Organon
arnostlobel
I actually recommend using Transaction directly in the code (where a model gets changed) depending on the Automatic Transaction mode, of which support will be phased out in Revit soon.
Arnošt Löbel
