Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
SectionBox intersect with other elements
5 REPLIES 5
Ning_Zhou
611 Views, 5 Replies
is there a way to get intersection point between "4 edges" of SectionBox, and other elements, say a lined based family instance, or simply a model curve?
seems SectionBox don't have any geometry info., the only useful workaround is BoundingBoxXYZ, but again, how can you get "4 edges" of BoundingBoxXYZ?
any hint will be very much appreciated.
5 REPLIES 5
Ning_Zhou
in reply to: Ning_Zhou
just find that section box on specific view cannot be retrieved correctly using the following code, if there're multiple 3D views w/ section box on:
List<Element> sbs = new FilteredElementCollector(doc, v3d.Id).OfCategory(BuiltInCategory.OST_Section).ToList();
seems that v3d.Id filter doesn't make any difference!? so how can you get specific section box on specific view?
i'm still using 2014.
Ning_Zhou
well, seems section box can be directly retrieved from 3d view, overthinking again!
Joe.Ye
Hi Ning,
BoundingBoxXYZ.Max and BoundingBoxXYZ.Min can return the maximum and minimum points coordinates of the box.
And then you can compose the 4 edges's curve from the above two coordinates.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
jeremytammik
Hi Ning,
Shall we consider this resolved for the moment, then?
Can you start a new thread if anything else crops up?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Autodesk Developer Network, ADN Open
The Building Coder
Ning_Zhou
in reply to: Joe.Ye
thanks Joe, that's what i'm going to use for now even though i'm not quite sure the case of rotated section box.
Rail Community
