ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Exporting issues - colour problem
16 REPLIES 16
Message 1 of 17
Chad-Smith
1083 Views, 16 Replies
There is something wrong with the Export process.
It doesn't matter which file format I go out to, it is messing up the RGB values in the resulting file.
You can see in the attached screenshots that some of the scan is correct, other parts are seethrough, and others are like static (noise) you would see on an analogue TV.
It also doesn't matter what file I use. They all produce the same result.
This is also consistent when linking into Revit and Navisworks.
16 REPLIES 16
Message 2 of 17
ryan.frenz
in reply to: Chad-Smith
Hi Chad,
I assume this is more than one scan (RCS)?  Could you attach the RCP file for our reference?  I think this may be a known issue the team is working on.
Thanks for using ReCap Pro.
Ryan
Message 3 of 17
Chad-Smith
in reply to: ryan.frenz
It is just a single scan.
Attached is the .RCP file as requested.
Message 4 of 17
cloudyao
Hi Chad,
It seems that you deleted some points in the RCP which may be the cause of export problem. Could you try to export the whole scan? You can create a new project with the RCS file in previous RCP's support folder.
Cloud Yao
Message 5 of 17
Chad-Smith
in reply to: cloudyao
That is indeed what I did.
I was doing some testing using the sample files before I jumped into something customised. With the warrior example I wanted to clip out the statue and do some testing in Revit.
I did as you said and the resulting exported .RCS file will all the points works perfectly fine.
From what you are saying it sounds like there might be a bug which needs to be addressed?
Message 6 of 17
cloudyao
Hi Chad,
Thank you very much for what you did! We've already logged a similar bug:The points RGB value nearby selection for delete may be incorrect during exporting.
 But unfortunately I can't reproduce it now. Is it possible for you to attach the RCS file?
Cloud Yao
Message 7 of 17
It was too big to upload here, so you can find the download on my 360 account.
http://a360.co/18Uxkt5
Message 8 of 17
cloudyao
Hi Chad,
Thanks for sharing the exported RCS. You can change far plane to 50 or 100 for seethrough points. Could you also upload the original RCS file so that I can check how those noise points are generated.
Best Regards,
Cloud Yao
Message 9 of 17
Here is a link for the original .RCS file.
http://a360.co/1696nYb
BTW, thanks for the time taken to look into this.
Message 10 of 17
cloudyao
Thanks for sharing the file. It's quite big. I'm downloading the file.
BTW, which version of ReCap are you using? You can get the version in the Control Panel->Programs->Programs and Features.
Message 11 of 17
Yes it is big. Just under 1 GB.
The version is 1.0.100.12
Message 12 of 17
cloudyao
Hi Chad,
We've already release ReCap Pro(version 1.1). I can reproduce the export issue in 1.0 but can't reproduce it in latest code. The fix for it should have been in ReCap Pro.
ReCap Pro can open RCP files created by ReCap 1.0. So you can export project in ReCap Pro. As installing ReCap Pro will uninstall ReCap 1.0, you can find another machine and have a try.
Cloud Yao
Message 13 of 17
cloudyao
The download page is here: www.autodesk.com/recap, you can find the free trial of ReCap pro.
Cloud Yao
Message 14 of 17
OK, now I'm confused. I thought ReCap Pro was just a rebadged brand of ReCap Studio which comes with design products.
  1. Is ReCap Pro a different product with more features?
  2. The download says it's a Trial. Is ReCap Pro a paid product?
  3. I guess ReCap Studio will eventually get a 1.1 release with the fix?
Message 15 of 17
cloudyao
Hi Chad,
Actually, ReCap Pro is the 1.1 version of ReCap Studio. It adds an important feature "Registration" for trial and other functions such as import/export are still free to use.
Cloud Yao
Message 16 of 17
That did it. Big thanks!
Had I known that ReCap Pro was the successor to ReCap Studio, I would have upgraded long ago.
I think the description on the web page needs improvement to make this clearer.
Message 17 of 17
cloudyao
Glad to hear that!
Cloud Yao
Rail Community
