Quantity Takeoff (Read Only)
Composite walls in QTO
1 REPLY 1
adrishi
1195 Views, 1 Reply
As Revit generates composite walls - how do I get QTO to create schedules of each of the component parts of the wall rather than an area of the composite item which I get at the moment?  I need to know the different areas of the materials as this will vary from inside to outside and will be priced and installed by different contractors.
1 REPLY 1
in reply to: adrishi
Did you figure out a solution for this??
John
