ObjectARX
VB.NET - Explode Entity
1 REPLY 1
482 Views, 1 Reply
Hi, Is't possible to have an idea about "how can we explode an entity" using VB.NET. Thanks. Erik
1 REPLY 1
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim appObj As Autodesk.AutoCAD.Interop.AcadApplication
Dim docObj As Autodesk.AutoCAD.Interop.AcadDocument
appObj = GetObject(, "AutoCAD.Application.17")
docObj = appObj.ActiveDocument
Dim regionObj As AcadRegion = docObj.HandleToObject("131")
MsgBox(ExplodeRegion(regionObj).Count)
End Sub
Public Function ExplodeRegion(ByVal regionObj As AcadRegion) As ArrayList
Dim arr As New ArrayList
Dim arrObjects As Object = regionObj.Explode
Dim i As Integer = 0
Dim booIsEndOfIndex As Boolean = False
Do While Not booIsEndOfIndex = True
Try
arr.Add(arrObjects(i))
i = i + 1
Catch ex As Exception
End Try
Loop
Return arr
End Function
”Boost
