ObjectARX
how to use objectARX by visual studio2010(autocad2013)???
2 REPLIES 2
618 Views, 2 Replies
i want to know how to study objectarx...
please help me
2 REPLIES 2
philippe.leefsma
Start there:
http://www.autodesk.com/developautocad
Comeback when you are done 🙂
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
tbrammer
I can highly recommend to build and use the ARXDBG tool. (As soon as you know how to compile & run an ARX)
You'll find it in the ARX folder under samples\database\ARXDBG.
It is a great help to understand ARX and what's inside a DWG.
Besides this the project itself uses quite a lot of the ARX API.
Cheers
--Thomas
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
”Boost
