I have a developer license for Acad 2018. When I start Acad 2018 it shows the splash screen and the text along the bottom of it changes as it's loading things, "Loading dll", "Loading customization files", etc. Then it pauses on "Checking license" for between 60 and 75 seconds, then it continues on and Acad opens shortly after that.
I have Acad 2016 developer license and it doesn't behave this way. There is a guy sitting 8 feet away from me (yes... I need a bigger cubical) and his Acad 2018 with developer licensing loads normally.
What is causing this? How can I fix this?
Thanks in advance!
Solved by Alexander.Rivilis. Go to Solution.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
