ObjectARX
ARX in XP Pro v. Windows 7
7 REPLIES 7
Message 1 of 8
EMD1954
441 Views, 7 Replies
I have about 26 ARX projects for Acad2010 compiled with Visual Studio 2008.  My operating system is Windows XP Pro so everything is x32.  I bought a new laptop which is running Windows 7 Pro that tells me that my ARX routines are not compatible and they won't load.  I assume that means I have to recompile with x64 (with inc-x64 and lib-x64)?
Is there a simple way to compile x32 and x64 versions within the same project or do I have to maintain two different projects (a lot of files and keeping track of changes) for each item until I have everything in Windows 7?
Any help would be much appreciated.
Ed
7 REPLIES 7
Message 2 of 8
Alexander.Rivilis
in reply to: EMD1954
If your's solutions (projects) was created with ObjectARX Wizard then they has two solution platform: Win32 and x64
You can build both arx-files with help of menu Build->Batch build...
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
EMD1954
They were built with the ARX Wizard in Visual Studio 2005 (before Windows 7) and then I migrated them to Visual Studio 2008 a few years ago.  My configuration manager only has Win32.  If you know a simple way to create a (e.g.) Win64 configuration, I'd appreciate it.
Ed
Message 4 of 8
Alexander.Rivilis
IMHO simplest way is creating new solution with ObjectARX Wizard and import all files from old solution to new solution.
Expert Elite Member
Message 5 of 8
EMD1954
Thanks.
Message 6 of 8
EMD1954
Okay, almost there.  I realized that I had not installed the x64 features to VC2008 so I installed them.  Then, using the configuration manager, I created a new configuration called "Releasex64".  I went through all of the settings in the properties dialog and got everything to work fine for my static library files. (I have a lot of common subroutines and functions shared by my ARX projects).   I even ran the "batch build" so that it did both of them successfully.
Then I opened one of my main projects and created the same configurations.  I put the appropriate "inc" and "lib" paths for each configuration and made sure that the proper library files were in the proper directories (e.g. my "Common32.lib" was in lib-win32 and "Common64.lib" was in lib-x64).  I also have the header files in the proper directories and have #included them in my StdAfx.h file.
Everything seems right to me but I get the "unresolved external symbol" error because it's not finding my libraries.  FYI, if I manually add the appropriate library files to my project under "Miscellaneous Files", both the Win32 and x64 versions of my arx files work perfectly - the problem with that is that I have to only have the appropriate library files under "Miscellaneous Files" which means I manually have to make changes for each configuration build.
Any ideas? Thanks in advance,
Ed
Message 7 of 8
owenwengerd
You need to define _WIN64 in order to tell the windows headers to pull in the 64 bit libraries.
Owen Wengerd
ManuSoft
Owen Wengerd
ManuSoft
Message 8 of 8
EMD1954
in reply to: owenwengerd
Thank you all.
In case someone else has the same issue, here is what I did.  Everything works fine and I now have succefully compiled applications in Win32 and x64:
  1. I installed the x64 features to VC2008.
  2. Using the Configuration Manager, I created a new configuration x64 copying from Win32 so all of my settings would be the same (FYI, this didn't work perfectly and there were a handful of busts so you need to check everything).
  3. In VC2008 "Tools->Options->Projects and Solutions->VC++ Directories", I set the Include and Library paths for the x64 configuration so I had the inc-x64 and lib-x64 listed as appropriate (as I had done with Win32).
  4. I created my library files for both configurations and named them e.g. MyCommonLib_01(32).lib and MyCommonLib_01(64), etc., and I put them in a directory called e.g. "MyLibraries" which is also listed as in #3 above for both the Win32 and x64 configurations.
  5. For each project, I listed the appropriate library files in "Configuration Properties->Linker->Input" and made sure I #included the .h file in StdArx.h.
  6. I set up a batch build, and it builds both configuration for me.
As I said, this worked fine for every one of my library and project files.
Good luck,
Ed
”Boost
