I used to derive Acad's "CAdUiDockControlBar" to display my own MFC dialog on AutoCAD, it works well, but its minisize button failed to work, so can anyone give me an example of DockingPanel floating on AutoCAD (C++ OjbectARX)?
Maybe you should derive from CAcUiDockControlBar instead?
I tested my code on AutoCAD 2008 , maybe ACAD's higher version solves this problem?
The CAcUiDockControlBar class adds to the CAdUiDockControlBar class a behavior common to AutoCAD dockable tools: when the user moves the mouse cursor out of the control bar region, the focus is automatically given back to AutoCAD.
I changed CAdUiDockControlBar to CAcUiDockControlBar, but the problem still exist.
I just checked, and it looks like AutoCAD 2008 has a properties palette derived from CAcUiPalette. Maybe that is why you're having trouble.
