.NET
xref in xref
4 REPLIES 4
410 Views, 4 Replies
xref in xref
I have to make all xrefs's to relative path xrefs: I found a solution that
works fine in the first level of xref.
Now I want to find out, if a xref is not referenced to the main drawing, so
it is an xref in an xref.
Has anyone an idea?
roland
4 REPLIES 4
Ok, here now a picture, for what I
mean:
[img src="@116199"]
My Code:
I can find out which xref the blocktable contains,
but not if it is from the main drawing or from a subdrawing (xref)
Private
size=2>
Function
FindXrefRecursive(
ByRef db
As Database,
color=#0000ff size=2>ByVal
Lev
size=2>As
size=2>Integer
size=2>ByVal
dt
size=2>As
System.Data.DataTable,
size=2>ByVal
baseKey
size=2>As
size=2>String
size=2>As
color=#0000ff size=2>Integer
size=2>Dim
i
size=2>As
size=2>Integer
0
Dim tm
color=#0000ff size=2>As
DBTransactionManager = db.TransactionManager
size=2>Dim
myT
size=2>As
Transaction =
tm.StartTransaction
size=2>Try
face="Courier New">Dim
bt
As BlockTable =
CType
size=2>(tm.GetObject(db.BlockTableId, OpenMode.ForRead,
color=#0000ff size=2>False
BlockTable)
Dim btr
As
size=2> BlockTableRecord
Dim
size=2> urOrg
As
face="Courier New"> Uri
size=2>Dim
file2load
size=2>As
color=#0000ff size=2>String
Dim
size=2> dbX
As
face="Courier New">
Autodesk.AutoCAD.DatabaseServices.Database
size=2>For
size=2>Each
btrID
size=2>As
ObjectId
size=2>In
bt
btr =
CType(tm.GetObject(btrID,
OpenMode.ForRead,
False
face="Courier New">), BlockTableRecord)
color=#0000ff size=2>If
btr.IsFromExternalReference
size=2>Then
urOrg =
size=2>New
Uri(db.OriginalFileName)
If
size=2> btr.PathName.StartsWith(
size=2>"."
color=#0000ff size=2>Then
file2load =
Microsoft.VisualBasic.FileIO.FileSystem.CombinePath(IO.Path.GetDirectoryName(db .OriginalFileName),
btr.PathName)
size=2>Else
file2load =
btr.PathName
End
size=2>If
'add to
table:
'dt.Rows.Add(baseKey &
color=#800000 size=2>"."
& i, btr.PathName,
file2load
dbX =
New Database(
size=2>False
size=2>)
dbX.ReadDwgFile(file2load, IO.FileShare.ReadWrite,
size=2>Nothing
size=2>)
FindXrefRecursive(dbX, Lev + 1, dt, baseKey &
& i)
dbX.Dispose()
i += 1
size=2>End
size=2>Next
size=2>Finally
size=2>myT.Dispose()
End
size=2>
size=2>Try
face="Courier New">End
Function
I have
works
Has anyone
an idea?
roland
title="AcDbXrefGraphNode::btrId Function">AcDbXrefGraphNode
class=492453323-21042006> can be used.
class=492453323-21042006>I don't have sample around though.
mean:
[img src="@116199"]
My Code:
contains, but not if it is from the main drawing or from a subdrawing
(xref)
Private
size=2>
Function
FindXrefRecursive(
ByRef
db
As Database,
ByVal Lev
size=2>Integer
size=2>ByVal
dt
size=2>As
baseKey
size=2>String
) A
s
size=2>Dim
i
size=2>As
size=2>Integer
0
Dim tm
size=2>Dim
myT
size=2>As
Transaction =
tm.StartTransaction
size=2>Try
bt
As BlockTable =
CType
size=2>), BlockTable)
Dim
size=2> btr
As
face="Courier New"> BlockTableRecord
color=#0000ff size=2>Dim
urOrg
size=2>As
Uri
Dim file2load
As
face="Courier New">String
dbX
size=2>As
size=2>For
size=2>Each
btrID
size=2>As
ObjectId
size=2>In
bt
btr =
CType
size=2>(tm.GetObject(btrID, OpenMode.ForRead,
size=2>False
BlockTableRecord)
If
urOrg =
color=#0000ff size=2>New
If
size=2>"."
file2load
.OriginalFileName), b tr.PathName)
color=#0000ff size=2>Else
size=2>file2load = btr.PathName
size=2>End
'add to
table:
& i, btr.PathName,
file2load
dbX =
New
Database(
False,
False
F alse
size=2>,
Nothing
baseKey &
face="Courier New"> & i)
dbX.Dispose()
i +=
1
End
If
color=#0000ff size=2 ce="Courier New" fa>Next
face="Courier New" color=#0000ff size=2>Finally
face="Courier New">myT.Dispose()
size=2>End
color=#0000ff size=2>Try
Function
I have to make
works fine in
Has anyone
an idea?
roland
Autodesk.AutoCAD.DatabaseServices.XrefGraph
Autodesk.AutoCAD.DatabaseServices.XrefGraphNode
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Roland Jungreithmayr" wrote in message news:5247009@discussion.autodesk.com...
Ok, here now a picture, for what I mean:
[img src="@116199"]
My Code:
I can find out which xref the blocktable contains, but not if it is from the main drawing or from a subdrawing (xref)
Private Function FindXrefRecursive(ByRef db As Database, ByVal Lev As Integer, ByVal dt As System.Data.DataTable, ByVal baseKey As String) A s Integer
Dim i As Integer = 0
Dim tm As DBTransactionManager = db.TransactionManager
Dim myT As Transaction = tm.StartTransaction
Try
Dim bt As BlockTable = CType(tm.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
Dim btr As BlockTableRecord
Dim urOrg As Uri
Dim file2load As String
Dim dbX As Autodesk.AutoCAD.DatabaseServices.Database
For Each btrID As ObjectId In bt
btr = CType(tm.GetObject(btrID, OpenMode.ForRead, False), BlockTableRecord)
If btr.IsFromExternalReference Then
urOrg = New Uri(db.OriginalFileName)
If btr.PathName.StartsWith(".") Then
file2load = Microsoft.VisualBasic.FileIO.FileSystem.CombinePath(IO.Path.GetDirectoryName(db .OriginalFileName), b tr.PathName)
Else
'add to table:
'dt.Rows.Add(baseKey & "." & i, btr.PathName, file2load)
dbX = New Database(False, False)
dbX.ReadDwgFile(file2load, IO.FileShare.ReadWrite, F alse, Nothing)
FindXrefRecursive(dbX, Lev + 1, dt, baseKey & "." & i)
dbX.Dispose()
i += 1
Next
Finally
myT.Dispose()
End Try
End Function
"Roland Jungreithmayr" schrieb im Newsbeitrag news:5242435@discussion.autodesk.com...
Has anyone an idea?
roland
Thanks Tony + Jimmy,
I tried now the following code, but I don't know
which informations now are usefull for me:
Dim graphXref As XrefGraph
graphXref =
db.GetHostDwgXrefGraph(True)
Debug.WriteLine(graphXref.NumNodes)
For idx
As Integer = 1 To graphXref.NumNodes - 1
Dim nodeXref As
XrefGraphNode
nodeXref = graphXref.GetXrefNode(idx)
If Not nodeXref Is
Nothing Then
Dim btrId As ObjectId
btrId =
nodeXref.BlockTableRecordId
Dim BTR As BlockTableRecord =
CType(tm.GetObject(btrId, OpenMode.ForRead, False), BlockTableRecord)
Dim
path As String = BTR.PathName
Debug.WriteLine("xref = " & nodeXref.Name
& " path=" & path & " " & nodeXref.IsNested & " " &
nodeXref.NumIn & " " & nodeXref.NumOut)
Next
Result in Debugwindow (base on the drawing. from
which I made the screenshot)
face="Courier New">(Debug.WriteLine("xref = " & nodeXref.Name & " path="
& path & " " & nodeXref.IsNested & " " & nodeXref.NumIn
size=1>
xref = Polygon
path=..\..\..\Projekte\xref\Polygon.dwg True 1 0
face="Courier New" size=2>xref = quadrat path=C:\Projekte\xref\vz1\quadrat.dwg
False 2 0
xref = Main
path=..\..\..\Projekte\xref\Main.dwg False 1 4
face="Courier New" size=2>xref = Dreieck
path=..\..\..\Projekte\xrefUpPfad\vzU1\Dreieck.dwg True 1 0
face="Courier New" size=2>xref = kreis path=C:\Projekte\xref\vz1\vz2\kreis.dwg
True 1 0
mayby a quicktip for me?
roland
size=2>Autodesk.AutoCAD.DatabaseServices.XrefGraph
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
href="http://www.acadxtabs.com">
size=2>http://www.acadxtabs.com
size=2>"Roland Jungreithmayr" <
href="mailto:roland@thening.at">
size=2>roland@thening.at
> wrote in message
size=2>news:5247009@discussion.autodesk.com
size=2>...
[img
src="@116199"]
My Code:
(xref)
String) A s Integer
tm.StartTransaction
Try
Dim
Dim urOrg As Uri
Dim
In bt
BlockTableRecord)
urOrg = New
file2load =
Else
End
If
'add to table:
file2load)
baseKey & "." & i)
dbX.Dispose()
i += 1
End
If
Next
Finally
myT.Dispose()
End Try
End
Function
> schrieb im
Newsbeitrag
face=Arial size=2>news:5242435@discussion.autodesk.com
face=Arial size=2>...
xref.
drawing, so
Has anyone an
idea?
roland
Forma Design Contest
