Hey Everyone,
I have been using vb.net for about3 or 4 months now. i have made a program that reads the location of drawings from a word file and then copies and renames the file. i am interested in having my program print the drawings using autocad. Here is a copy of the code i am using.
' Autodesk AutoCAD 2000 or above and Universal Document Converter
' should be installed on your PC
' Define constants
Const acExtents = 1
Const acScaleToFit = 0
' Run AutoCAD as COM-server
On Error Resume Next
Dim App As Object
'Dim App As New AutoCAD.AcadApplication
Dim Drawing As Object
Dim Layout As Object
Dim ActiveSpace As Object
Dim n As Integer = 0
Dim DrawType As String = ""
Dim FilePath As String = ""
Dim MyDwg As String = ""
Dim Dwg As Object
Dim DwgClass As String = ""
Dim k As Integer = 0
Dim strFilePath As String = ""
App = CreateObject("AutoCAD.Application")
For n = 0 To DataGridView1.RowCount - 1 'Determines what File Type the user selected it was, and whether or not the user select a file type.
If DataGridView1.Item(2, n).Value = "False" And DataGridView1.Item(3, n).Value = "False" And DataGridView1.Item(4, n).Value = "False" Then 'Determines whether or not the user select a file type.
MsgBox("You must select what type of drawing " & DataGridView1.Item(0, n).Value & " is.", CType(vbOKOnly + vbCritical, MsgBoxStyle))
Exit Sub
Next n
For n = 0 To DataGridView1.RowCount - 1 'Determines what File Type that the user selected
MyDwg = DataGridView1.Item(0, n).Value
MsgBox(MyDwg)
If DataGridView1.Item(2, n).Value = "True" Then
DrawType = ".dwg"
ElseIf DataGridView1.Item(3, n).Value = "True" Then
DrawType = ".idw"
ElseIf DataGridView1.Item(4, n).Value = "True" Then
DrawType = ".pdf"
Else
Exit Sub
Dwg = Split(MyDwg, "-") 'Splits the Drawing Name (MyDwg) into an array
DwgClass = Dwg(2)
Trim$(DwgClass)
MsgBox(DwgClass)
For k = 0 To UBound(CType(Dwg, Array))
Dwg(k) = Trim$(Dwg(k))
Next k
If DwgClass Like "###" Then '### stands for 3 numeric values
MyDwg = Dwg(0) & "-" & Dwg(1) & "-" & Dwg(2)
ElseIf DwgClass Like "###[A-Z]" Then '### stands for 3 numeric values and [A-Z] is a wildcard of only these letters and are Capital
Else
MsgBox("There seems to be a problem with the drawings class.", vbOKOnly + vbCritical)
MsgBox(DwgClass)
Select Case Microsoft.VisualBasic.Left$(DwgClass, 1)
Case "2"
strFilePath = strelement & My.Settings.PIDText & MyDwg & DrawType 'My.Settings.PIDText gets folder structure from config file)
Case "3"
strFilePath = strelement & My.Settings.VesselText & MyDwg & DrawType 'My.Settings.VesselText gets folder structure from config file
Case "4"
strFilePath = strelement & My.Settings.StructuralText & MyDwg & DrawType 'My.Settings.StructuralText gets folder structure from config file
Case "5"
strFilePath = strelement & My.Settings.PipingText & MyDwg & DrawType ''My.Settings.PipingText gets folder structure from config file
Case "6"
strFilePath = strelement & My.Settings.ISOText & MyDwg & DrawType 'My.Settings.ISOText gets folder structure from config file
Case "7"
strFilePath = strelement & My.Settings.InstElecText & MyDwg & DrawType 'My.Settings.InstElecText gets folder structure from config file
Case "8"
strFilePath = strelement & My.Settings.MembraneTubesText & MyDwg & DrawType 'My.Settings.MembraneTubesText gets folder structure from config file
Case Else
MsgBox(DwgClass & " - This Is An Invalid Drawing Class", CType(vbOKOnly + vbCritical, MsgBoxStyle))
End Select
App.Preferences.System.SingleDocumentMode = False
Drawing = App.Documents.Open(strFilePath, False)
If Drawing = Not Nothing Then
' Change AutoCAD preferences for scaling the drawing to page
If Drawing.ActiveSpace = 0 Then
ActiveSpace = Drawing.PaperSpace
Layout = ActiveSpace.Layout
Else
ActiveSpace = Drawing.ModelSpace
Layout.PlotType = acExtents
Layout.UseStandardScale = True
Layout.StandardScale = acScaleToFit
' Plot the drawing
Call Drawing.Plot.PlotToDevice("Dell AIO Printer A920.pc3")
' Close drawing
Drawing.Close(False)
Drawing = Nothing
System.Threading.Thread.Sleep(30000) 'added so that there is a chance for the drawing to print out before the other one starts.
Next n
I cant use the AutoCAD API because this is suppose to work for multiple versions of autocad. I am sure That there is a better way but i do not know how. Can anyone help me.
Dan
