.NET
VB.NET + COM GetEntity gives type mismatch
7 REPLIES 7
Message 1 of 8
865 Views, 7 Replies
The following code keeps throwing a type mismatch on the GetEntity line
What am i doing wrong?
Dim obj As Object = Nothing
Try
    Dim pnt As Object = Nothing
    doc.Utility.GetEntity(obj, pnt, "test")
Catch ex As Exception
    Return False
End Try
The following code as well:
Dim obj as Object = Nothing
Try Dim pnt As Object = Nothing doc.Utility.GetEntity(obj) Catch ex As Exception Return False End Try
When i give no parameters i get an error that the number of parameters is not correct. That's fine, but that would imply
- that there is an overload accepting 1 parameter
- that the 'obj' parameter is of the wrong type
7 REPLIES 7
Message 2 of 8
Alexander.Rivilis
Dim pnt(2) As Object
Try
    Return False
End Try
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
in reply to: Alexander.Rivilis
unfortunately no 🙂
I'm running a thread in another forum as well and it seems that autocad not being the top window at the time seems to have an effect on this issue
Message 4 of 8
Alexander.Rivilis
Sorry. What about:
Dim pnt(2) As Double
Expert Elite Member
Message 5 of 8
yes i tried that, but it didn't work
and about bringing autocad to the front: wrong track. I built in a 500ms delay and the call rejected error disappears and the original error reappears
Message 6 of 8
I gave up and used early binding instead. That worked
Message 7 of 8
@Anonymous wrote:
unfortunately no 🙂
Are these replies to feedback at another forum?
Message 8 of 8
No,
i was referencing some findings in the other thread which at first glance seemed to have relevance.
i didn't want to cross post, but the gentleman in the other thread recommended this group so i posted here, but since he kept helping i didn't want to abandon that thread
Forma Design Contest
