Hi!
I doesen't acces or modify nothing in a ActiveLayout.
I'm using c# and interop and need to plot to a file a dwg.
The plot to file works well, but I need to change some properties like Plot Scale or Plot Type.
A conversion error occours.
In second place, the DefaultPlotStyleTable doesen't work too.
Somebody can helpe me?
My test code:
using System;
using System.IO;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
namespace ProcessoCAD
static class Program
private static Autodesk.AutoCAD.Interop.AcadApplication oAcadApp = null;
private static string sAcadID = "AutoCAD.Application.18";
/// <summary>
/// The main entry point for the application.
/// </summary>
[STAThread]
static void Main()
// Abre AutoCAD
try
oAcadApp = (Autodesk.AutoCAD.Interop.AcadApplication)System.Runtime.InteropServices.Marshal.GetActiveObject(sAcadID);
catch
System.Type AcadProg = System.Type.GetTypeFromProgID(sAcadID);
oAcadApp = (Autodesk.AutoCAD.Interop.AcadApplication)System.Activator.CreateInstance(AcadProg);
// Inicia ciclo de execução
if (oAcadApp != null)
string StyleTable = "AZEVEDO.ctb";
oAcadApp.Visible = true; //could leave this false to hide Acad from the user
Autodesk.AutoCAD.Interop.AcadDocument dm; // = oAcadApp.ActiveDocument;
dm = oAcadApp.Documents.Open("d:\\teste\\Teste.dwg", true, null);
dm.SetVariable("BACKGROUNDPLOT", 0);
dm.ActiveSpace = AcActiveSpace.acPaperSpace;
dm.ActiveLayout.PlotType = AcPlotType.acExtents;
dm.ActiveLayout.StandardScale = AcPlotScale.ac1_1;
oAcadApp.Preferences.Output.DefaultPlotStyleTable = StyleTable;
dm.Regen(AcRegenType.acActiveViewport);
// dm.Application.ZoomExtents();
// dm.Regen(AcRegenType.acAllViewports);
dm.Plot.QuietErrorMode = true;
dm.Plot.NumberOfCopies = 1;
dm.Plot.PlotToFile("d:\\teste\\Teste.pdf", "C:\\Program Files\\AutoCAD 2010\\UserDataCache\\Plotters\\DWG To PDF.pc3");
// dm.Plot.PlotToFile("d:\\teste\\Teste.plt", "C:\\Program Files\\AutoCAD 2010\\UserDataCache\\Plotters\\DWF6 ePlot.pc3");
//dm.Close(null, null);
//oAcadApp.Quit();
Try this code snip, change to your settins and file name:
' Abre AutoCAD Try oAcadApp = DirectCast(System.Runtime.InteropServices.Marshal.GetActiveObject(sAcadID), Autodesk.AutoCAD.Interop.AcadApplication) Catch Dim AcadProg As System.Type = System.Type.GetTypeFromProgID(sAcadID) oAcadApp = DirectCast(System.Activator.CreateInstance(AcadProg), Autodesk.AutoCAD.Interop.AcadApplication) End Try oAcadApp.Visible = True Try ' Inicia ciclo de execução If oAcadApp IsNot Nothing Then Dim StyleTable As String = "MyPlotStyle.ctb" ' set application to be visible oAcadApp.Visible = True ' expand window to max oAcadApp.WindowState = AcWindowState.acMax 'could leave this false to hide Acad from the user Dim dm As Autodesk.AutoCAD.Interop.AcadDocument ' = oAcadApp.ActiveDocument; dm = oAcadApp.Documents.Open("c:\test\layouts.dwg", True, Nothing) ' set desired layouts first dm.ActiveLayout = dm.Layouts.Item("FLOOR PLAN") dm.SetVariable("BACKGROUNDPLOT", 0) dm.ActiveSpace = AcActiveSpace.acPaperSpace dm.ActiveLayout.PlotType = AcPlotType.acExtents dm.ActiveLayout.StandardScale = AcPlotScale.ac1_1 dm.Utility.Prompt(vbLf & oAcadApp.Preferences.Output.DefaultPlotStyleTable) 'MsgBox(dm.ActiveLayout.GetPlotStyleTableNames(0).ToString) Dim pstyle As String Dim pstyles() As String = TryCast(dm.ActiveLayout.GetPlotStyleTableNames, String()) For Each pstyle In pstyles If String.Compare(StyleTable, StringComparison.InvariantCulture) = 0 Then oAcadApp.Preferences.Output.DefaultPlotStyleTable = StyleTable Else oAcadApp.Preferences.Output.DefaultPlotStyleTable = "acad.stb" End If Next dm.Regen(AcRegenType.acActiveViewport) ' dm.Application.ZoomExtents(); ' dm.Regen(AcRegenType.acAllViewports); dm.Plot.QuietErrorMode = True dm.Plot.NumberOfCopies = 1 ' dm.Plot.PlotToFile("d:\\teste\\Teste.plt", "C:\\Program Files\\AutoCAD 2010\\UserDataCache\\Plotters\\DWF6 ePlot.pc3"); 'dm.Close(null, null); 'oAcadApp.Quit(); dm.Plot.PlotToFile("c:\test\layouts.pdf", "C:\Program Files\AutoCAD 2009\UserDataCache\Plotters\DWG To PDF.pc3") End If Catch ex As System.Exception MsgBox(ex.Message & vbLf & ex.StackTrace) End Try End Sub
Thanks for help!
I converted the code to VB, but when it executes the line
dm.ActiveLayout = dm.Layouts.Item(0)
I have a conversion error:
"Unable to cast COM object of type 'Autodesk.AutoCAD.Interop.Common.AcadLayoutsClass' interface type 'Autodesk.AutoCAD.Interop.Common.IAcadLayouts.' This operation failed because the QueryInterface call on the COM component for the interface with IID '{9AEBED7B-03A9-4C9E-B358-4E95FA5B07F4}' failed due to the following error: No support for this interface (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Is it because my dwg or a wrong reference?
I'm send the dwg and need to use the AR2 Layout.
Sorry for the belating I was busy
I tested code I posted above on my machine -
the plotting is looks good,
See plot copy log:
Job: - Plotted Job ID: 1 Sheet set name: Date and time started: 24.10.2012 20:52:47 Date and time completed: 24.10.2012 20:52:49 UserID: Олег Profile ID: <<Unnamed Profile>> Total sheets: 1 Sheets plotted: 1 Number of errors: 0 Number of warnings: 0
Thanks for help!
I reinstall the ARX SDK for 2010 and works fine!
But, the DefaultPlotStyleTable insists in not work.
The code set all preferences, but the result (in pdf) doesn't reflect them.
For example, if I use the monochrome.ctb to plot into a pdf, it's doesn't plot in monochrome.
I saw too that a file stb raises a exception.
Hi!
I include the line dm.ActiveLayout.StyleSheet = "AZEVEDO.ctb" and all works fine!
Thanks for help!!!!
Following code examples for those who have questions:
VB
Dim oAcadApp As Autodesk.AutoCAD.Interop.AcadApplication
Dim sAcadID = "AutoCAD.Application.18"
' Abre AutoCAD
Try
Catch
End Try
Try
Dim StyleTable As String = "AZEVEDO.ctb"
dm = oAcadApp.Documents.Open("d:\teste\teste.dwg", True, Nothing)
dm.ActiveLayout.PlotWithPlotStyles = True
dm.ActiveLayout.UseStandardScale = True
dm.ActiveLayout.CenterPlot = True
' dm.ActiveLayout.CanonicalMediaName = "ISO_B5_(182.00_x_237.00_MM)"
oAcadApp.Preferences.Output.AutomaticPlotLog = False
oAcadApp.Preferences.Output.ContinuousPlotLog = False
'oAcadApp.Preferences.Output.DefaultOutputDevice = "DWG To PDF.pc3"
oAcadApp.Preferences.Output.DefaultPlotStyleTable = "AZEVEDO.ctb"
dm.ActiveLayout.RefreshPlotDeviceInfo()
dm.Plot.PlotToFile("d:\teste\layouts.pdf", "C:\Program Files\AutoCAD 2009\UserDataCache\Plotters\DWG To PDF.pc3")
'oAcadApp.Quit();
End Try
C#
using System;
using System.IO;
/// <summary>
/// </summary>
[STAThread]
static void Main()
// Abre AutoCAD
try
catch
// App Visível
// Expande Janela
oAcadApp.WindowState = AcWindowState.acMax;
// Documento
// Plotagem Síncrona
// Seleciona Layout
// Configurações da Plotagem
dm.ActiveLayout.PlotWithPlotStyles = true;
dm.ActiveLayout.UseStandardScale = true;
dm.ActiveLayout.CenterPlot = true;
dm.ActiveLayout.StyleSheet = "AZEVEDO.ctb";
// Aplica Estilo
// Gera Arquivo
dm.ActiveLayout.RefreshPlotDeviceInfo();
//oAcadApp.Quit();
