.NET
Total n00b trying to use .net to create ribbon bar addins
7 REPLIES 7
Message 1 of 8
2330 Views, 7 Replies
Ok im totally lost here with this.  Figured this after at least getting over the hurdle of trying to set up the project and all would be much easier to use and deploy (maybe even faster in AutoCAD) than what im trying to do right now using CUI files which can take 30-45 seconds to load each ribbon bar.
Trying to create extra ribbon tabs and pannels each with multiple items in drop down windows and such.  Basically im trying to get rid of the tool pallet function and replace it with this item.  So far I've done this just using the CUI editor in autocad but its time consuming (not easy to switch between macro's) and takes long to load on the first launch of it.
I really don't know much about VB or .net or anything.  Though I have been learning more recently, with a little bit in excel trying to make customized documents for my department.  I have AutoCAD 2010, and have Visual Studio 2010 Professional.  Any help would be apperciated, expecially if there is some templates that I could load easily, currently not having any luck with the files from the website ObjectARX 2010 or a AutoCAD2010VBNetTemplateSetup.zip I got from another site.
7 REPLIES 7
Message 2 of 8
Well at least I got a template up and runnig at least to debug mode now.
Another question I have is that is it possible to have a .dll (weather the one the main project one or a seperate file) load images into them?
Looking at loading some 2500 images maybe more.  Got about 500 to add right away and others to add over time.
Thats a small sample of what im doing.  Under each pull down there can be another 5-20 options.  Probably 10-12 tabs, each with 20 or so panels.  Any help pointing me into the right direction would be great!
All that was done in the autocad CUI, though its buggy and if it can be transfered between AutoCAD revs easier later on it would be great, and probably easier to edit for future updates.
Message 3 of 8
Hi there please look at te following post:
http://forums.autodesk.com/t5/NET/Create-custom-ribbon-tab-and-buttons-for-Autocad-mechanical-2011/t...
I'll think it will help you getting started.
Kind regards,
Irvin
Message 4 of 8
Alright im getting somewhere now.
Attached is my project file as is.  Finally was able to find a tutorial done from AU back in 2009
http://images.dcheetahimages.com/au.autodesk.com/ama/images/media/AU09_SpeakerHandout_CP208-2.pdf
So started going through it finally got a tab to be created, though now running in issues trying to get the panel to load with buttons.  I've copied it exactly though not sure what im doing wrong with this.
Below is the code so far (as can be seen also attached)
Though my one spot im having issues with is the AdskCommandHandler Class.  Specifically
 SendStringToExecute(_
ribBtn.CommandParameter, True, False, True)
Imports System
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.Windows
Public Class Testing
    Implements IExtensionApplication
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
        createRibbon()
    End Sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
    End Sub
    Private Sub CreateRibbon()
        'declare a ribboncontrol object
        Dim ribCntrl As RibbonControl = ComponentManager.Ribbon
        'create a ribbontab
        Dim ribTab As New RibbonTab()
        'set a few properties
        ribTab.Title = "AU2009"
        ribTab.Id = "AU2009"
        'add the tab to the ribbon
        ribCntrl.Tabs.Add(ribTab)
        'set as active tab
        ribTab.IsActive = True
    End Sub
    Private Sub addContent(ByVal ribTab As RibbonTab)
        'create the panel source
        Dim ribSourcePanel As RibbonPanelSource = New RibbonPanelSource()
        ribSourcePanel.Title = "Dev Tools"
        'now the panel
        Dim ribPanel As New RibbonPanel()
        ribPanel.Source = ribSourcePanel
        ribTab.Panels.Add(ribPanel)
        'create a button
        Dim ribButton1 As RibbonButton = New RibbonButton()
        ribButton1.Text = "Net Load"
        ribButton1.CommandParameter = "NETLOAD "
        ribButton1.ShowText = True
        ribButton1.CommandHandler = New AdskCommandHandler()
        'add the button
        ribSourcePanel.Items.Add(ribButton1)
    End Sub
End Class
Public Class AdskCommandHandler
    Implements System.Windows.Input.ICommand
    Public Function CanExecute(ByVal parameter As Object) As Boolean _
        Implements System.Windows.Input.ICommand.CanExecute
        Return True
    End Function
    Public Event CanExecuteChanged As EventHandler Implements _
        System.Windows.Input.ICommand.CanExecuteChanged
    Public Sub Execute(ByVal parameter As Object) Implements _
        System.Windows.Input.ICommand.Execute
        Dim ribBtn As RibbonButton = TryCast(parameter, RibbonButton)
        If ribBtn IsNot Nothing Then
            Autodesk.AutoCAD.ApplicationServices.Application.
                DocumentManager.MdiActiveDocument.
        End If
    End Sub
End Class
Any help apperciated.
Message 5 of 8
Hi Deathman,
I modifyed your code and in now displays a ribbon a tab buttons and fixed your command handler and add functions to remove the ribbon and use vb.net resourceimages. In the solution explorer click the project richt click propperties choose resources and then Add Resource.
Here's the code and revised project attached.
Imports System
Imports System.Drawing
Imports System.Drawing.Imaging
Imports System.IO
Imports System.Windows.Media.Imaging
        createRibbon()
    End Sub
    End Sub
    Public Sub createRibbon()
        Dim ribCntrl As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon
        If ComponentManager.Ribbon Is Nothing Then
            Return
        End If
        For i As Integer = 0 To ribCntrl.Tabs.Count - 1
            If ribCntrl.Tabs(i).Id.Equals("My_Rib_ID") Then
                Return
            End If
        Next
        'add the tab
        ribTab.Title = "ACME RIBBON"
        ribTab.Id = "My_Rib_ID"
        'create and add the panels
        addPanel1(ribTab)
        'set as active tab
    End Sub
    Private Sub removeRibbon()
        'find the custom tab using the Id
                ribCntrl.Tabs.Remove(ribCntrl.Tabs(i))
                Return
            End If
        Next
    End Sub
    Private Sub addPanel1(ByVal ribTab As RibbonTab)
        Dim ribSourcePanel As New RibbonPanelSource()
        ribSourcePanel.Title = "PanelName"
        'now the panel
        Dim ribbonbutton1 As New RibbonButton()
        ribbonbutton1.Text = "Net Load"
        ribbonbutton1.CommandParameter = "NETLOAD "
        ribbonbutton1.ShowText = True
        ribbonbutton1.ShowImage = True
        ribbonbutton1.Image = getBitmap(My.Resources.Rib_16)
        ribbonbutton1.LargeImage = getBitmap(My.Resources.Rib_32)
        ribbonbutton1.Orientation = System.Windows.Controls.Orientation.Vertical
        ribbonbutton1.Size = RibbonItemSize.Large
        ribbonbutton1.CommandHandler = New AdskCommandHandler()
        Dim ribbonbutton2 As New RibbonButton()
        ribbonbutton2.Text = "LINE"
        ribbonbutton2.CommandParameter = "LINE "
        ribbonbutton2.ShowText = True
        ribbonbutton2.ShowImage = True
        ribbonbutton2.CommandHandler = New AdskCommandHandler()
        Dim ribbonbutton3 As New RibbonButton()
        ribbonbutton3.Text = "Polyline"
        ribbonbutton3.CommandParameter = "PLINE"
        ribbonbutton3.ShowText = True
        ribbonbutton3.ShowImage = True
        ribbonbutton3.CommandHandler = New AdskCommandHandler()
        Dim ribbonbutton4 As New RibbonButton()
        ribbonbutton4.Text = "Circle"
        ribbonbutton4.ShowText = False
        ribbonbutton4.CommandParameter = "CIRCLE "
        ribbonbutton4.ShowImage = True
        ribbonbutton4.CommandHandler = New AdskCommandHandler()
        Dim ribbonbutton5 As New RibbonButton()
        ribbonbutton5.Text = "DialogLauncher"
        ribbonbutton5.CommandParameter = "properties "
        ribbonbutton5.ShowText = True
        ribbonbutton5.ShowImage = True
        ribbonbutton5.CommandHandler = New AdskCommandHandler()
        Dim rowpanel As New RibbonRowPanel()
        rowpanel.Items.Add(ribbonbutton2)
        rowpanel.Items.Add(New RibbonRowBreak())
        rowpanel.Items.Add(ribbonbutton3)
        rowpanel.Items.Add(ribbonbutton4)
        'and add it to source
        ribSourcePanel.DialogLauncher = ribbonbutton5
        ribSourcePanel.Items.Add(ribbonbutton1)
        ribSourcePanel.Items.Add(New RibbonSeparator())
        ribSourcePanel.Items.Add(rowpanel)
    End Sub
    Public Function getBitmap(ByVal image As Bitmap) As BitmapImage
        Dim stream As New MemoryStream()
        image.Save(stream, ImageFormat.Png)
        Dim bmp As New BitmapImage()
        bmp.BeginInit()
        bmp.StreamSource = stream
        bmp.EndInit()
        Return bmp
    End Function
End Class
        Return True
    End Function
        End If
    End Sub
End Class
Kind regards,
Irvin
Message 6 of 8
Thanks Irvin.  Between yours and found the full file script from the AU2009 was able to get a start on it.
Message 7 of 8
Hi
Thanks to this thread I have got some code running in AutoCAD 2011.
Out of interest where is the RibbonButton.CommandParameter documentation?  It took me a while to realise I needed a sapce at the end of the command string.
Regards
Message 8 of 8
The RibbonButton.CommandParameter really doesn't have much documentation that I know of.  Really its a thirdparty command added in to Mock the command line.
As for the space, and the reason for it after the command, it acts like an enter key.  Just like if you type in "pl" and hit space or enter after it, it will start the polyline command in autocad.
”Boost
