there is an event at the show of multiselect ribbontab on Civil3D?
regards Mario
I programming a Tool to set elevation from Selected objects to input Value, parsing layername or flatten to input value.
The reference for elevation (z-axis=0.0) is possible world or current ucs. To visible the current reference i change
the icon from ribbonbutton. That all works fine. To change the icon i use the "Autodesk.Windows.RibbonButton" because the "Autodesk.AutoCAD.Customization.RibbonButton" has no "Image and LargeImage" property.
In Civil3D activate on multiple objecttype-selection a new ribbon tab from 'state-kontextsensitive-multiselect-tab' (sorry i have only a german civil). On cui i have bound the ribbongroup to this tabs. If the tab is shown i must change the 'reference-ribbonbutton-icon'.
A solutions approach might also 'how do I get one from a "Autodesk.AutoCAD.Customization.RibbonButton" a "Autodesk.Windows.RibbonButton"'?
At the show? Do you mean when the Ribbon Tab is loaded?
Or even this.
regards Mario
Sorry,
I don't understand your question very well.
Maybe use the Copy or Clone method to copy it to the Other type of object? Just taking a guess.
I took a look at the RibbonButton Classes in
Autodesk.Windows & Autodesk.AutoCAD.Customization.
You may want to try asking this question in the ARX development area.
(http://forums.autodesk.com/t5/Autodesk-ObjectARX/bd-p/34)
But maybe this might help.
Sorry, I know not much help.
Good luck!
Hi Mario,
From what I understand, are you looking for an event that will let you know that the Ribbon is initialized.
Have you tried using the "Autodesk.Windows.ComponentManager.ItemInitialized" event ?
In the event handler, you can check if the ribbon is not null and then you know for sure that the Ribbon is ready.
void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e) { if (Autodesk.Windows.ComponentManager.Ribbon != null) { // Ribbon is ready... } }
