.NET
text rotation
2 REPLIES 2
sybold
448 Views, 2 Replies
text rotation
Text = New DBText
                Text.SetDatabaseDefaults()
                Text.Height = 2.25 * Application.GetSystemVariable("DIMSCALE")
                Text.Rotation = 300
                Text.TextString = coord
                Text.Layer = "GRID-TEXT"
Text.TextStyleId = newTSId If MIR = True Then Text.HorizontalMode = TextHorizontalMode.TextRight Text.VerticalMode = TextVerticalMode.TextBottom Else Text.HorizontalMode = TextHorizontalMode.TextLeft Text.VerticalMode = TextVerticalMode.TextBottom End If Text.AlignmentPoint = pt If ucs = True Then Text.TransformBy(Doc.Editor.CurrentUserCoordinateSystem) End If btr.AppendEntity(Text) tr.AddNewlyCreatedDBObject(Text, True) tr.Commit()
when placing text the rotation is off in autocad, i set it to 300 and in autocad it should be 270 degrees it is 269. am i doing something wrong?
Tags (2)
2 REPLIES 2
_gile
in reply to: sybold
Except when using the command line (i.e. SendStringtoExecute), the angles have to be expressed in radians.
Gilles Chanteau
GileCAD
GitHub
sybold
in reply to: sybold
Doh! thought it was in grads.
thanks!
”Boost
