I am looking at options to disable all functions during the start-up process when I netload “my.dll”. The only way I have found is by using the following code:
Dim BoolRes As Boolean
If BoolRes = False Then
Dim line As Line
line.ColorIndex = 1
End If
The action of trying to change a lines colour while it’s not open for write works perfectly. As in any of my functions after this process don’t load. Does anyone know of a better way than my above code? Or even why my code is a bad idea because it feels like a bad idea to me.
I believe you are talking IExtensionApplicationo.Initialze() method that you implemeted in your "my.dll", so that when your DLL is laoded, the code inside Initialze(0 runs and after that your command defined with [CommandMethod] in your "my.dll" no longer works.
Probably you know the code you showed to run inside Initialize() is wrong and will crash (you maybe showed the wrong delibrately).
The thing is that Autodesk makes IExtensionApplication.Initialize() silently swallow exception that raised inside Initialize() and the result is the assembly loading would be aborted, thus useless.
So, one MUST be very carefully to handle possible exceptions that may be raised inside Initialize(). The common approach would be wrap all code in Initialze() with try...catch block:
public void Initialize()
try
//Run your code here
catch
Document dwg=Application.DocumentManager.MdiActiveDocument;
dwg.Editor.WriteMessage("\nSomething went wrong when initializing...)
This way, even your code runs bad, the assemly loading will still be completed, and your custom commands in the assembly should be working.
However, you need to make sure how your commands should work, if your code in Initialize() failed. After all it serves some purpose to run code in Initialize(), which may impact how things can be done later.
Norman Yuan
Yes in initialize that’s correct.
My software has 100's of commands all in separate .vb documents. Like so:
00. StartUp_1.vb = (Contains initialize)
01. Function_1.vb = (Contains "function 1")
02. Function_1.vb = (Contains "function 2")
03. Function_1.vb = (Contains "function 3")
Each doc has a command, my initialize component checks my security on start-up. I the security fails I want NO commands to load in all documents. Like I said before, the sample section of code I shown at the top stops it dead in its tracks. The code surrounded in a try catch would allow the rest of the commands to load wouldn't it?
Methinks you're misunderstanding what Initialize() does... It gives you, the developer, an opportunity to prompt the user, configure some dependent settings, etc. when the code is loaded.... It does not prevent your subsequent classes from being loaded if some criteria is not met per-se.
Since there is no such pseudo-named NETUNLOAD functionality, you might consider using a two-stage assembly load procedure, such that if the necessary criteria is met via Initialize() when your primary assembly loads, your secondary assembly (the one with the CommandMethod attributes) is programmatically loaded... Else it is not loaded (i.e., no CommandMethods are registered).
Hope that makes (more?) sense.
"How we think determines what we do, and what we do determines what we get."
Thanks peeps for the help, but one of my problems in life is not articulating myself. I will try to simlify things.
How would I stop my dll loading from within my .dll using code when it's netloaded? Like I said at the top, the code I have provided will do this, I'm just not sure how safe this is, or if there is some chance it may not stop it every time.
Ta,
Martin.
@Anonymous wrote:Thanks peeps for the help, but one of my problems in life is not articulating myself. I will try to simlify things.
You've articulated yourself just fine, IMO.
You've clearly explained that you intentionally evaluate a code snippet which presumably throws an eNotOpenForWrite Exception, that you subsequently neglect to Catch... Couldn't be more clear.
I've already offered one maintainable option, which precludes any Exception(s) from being raised... perhaps someone smarter than I will pass through offering another, perhaps simpler, option that I am unaware of.
Cheers
Cheers
I don't think your suggestion would work with demand-loaded commands, and there's nothing wrong with throwing an exception. The only problem is that the OP seems to think that he must make an erroneous API call to raise an exception, rather than just throwing one.
@Anonymous wrote:Hi,
Dim line As Line
line.ColorIndex = 1
End If
I would suggest becoming more familiar with the tools you're trying to use.
You raise exceptions using the Throw statement, not by making erroneous API calls.
Dim line As Line
line.ColorIndex = 1
End If
... Just saw this, which answers my recent question; for some reason this post didn't show up on my iPhone, but does on Computer.
@BlackBox_ wrote:
Fair enough; so you're sayin something like:
if (<criteria is not met>)
throw new <?.>Exception();
... Would do the trick?
Yes. The managed runtime loader will catch any exception thrown. If the OP wants to inform the user that the commands are not available, he can display a message before throwing the exception.
... Would do the trick?Yes. The managed runtime loader will catch any exception thrown. If the OP wants to inform the user that the commands are not available, he can display a message before throwing the exception.
Thank you for clarifying... Perhaps in error, I picked up that this was 'a bad thing' to do in Initialize, and didn't realize one could intentionally employ Exceptions to prevent other assembly code from being loaded.
In contrast, I did learn from Gile's LispException helper Classes that one could do so when evaluating a ResultBuffer; I clearly didn't connect the dots.
As always, I appreciate the knowledge you share with the community.
Cheers
