When I START from Visual Studio, AutoCAD 2017 launches as expected, but I do not get a ribbon. And, when I type in RIBBON at the command line, I get unknown command. I have a desktop icon setup using the same TARGET switches that I have defined in the C# Project Properties for Command line arguments and working director. The desktop icon works fine.
I am sure I am missing something, but can't for the life of me "see it". I have projects setup for 2016 and 2015, setup similar, they work fine.
Solved by mcicognani. Go to Solution.
I guess you are using VS2015, isn't it? In this case there is a problem.
Please see http://forums.autodesk.com/t5/net/first-steps-with-autocad-2017-and-vs2015/td-p/6232024
http://adndevblog.typepad.com/autocad/2016/05/debugging-autocad-2017-using-visual-studio-2015.html
Facebook | Twitter | LinkedIn
