.NET
Run VS2005 with AUTOCAD 2006 LT
4 REPLIES 4
237 Views, 4 Replies
A simple question. Can I use AUTOCAD 2006 LT with my VS applications? Does it support COM?
Thank you.
André Cunha
4 REPLIES 4
AcadLT does not support COM Automation.
wrote in message news:5405516@discussion.autodesk.com...
it support COM?
Thank you.
André Cunha
Thank you for your reply.
Is there any way to overcome that problem?
André Cunha
More money for full Acad version + cost of customization (:
wrote in message news:5405522@discussion.autodesk.com...
André Cunha
AutoCAD LT is intentionally not programmable or extensible; if you need such
functionality, use the full version of AutoCAD.
AutoCAD 2006 should (more-or-less) work with all versions of Visual Studio
(as long as you stick to just the .NET APIs); AutoCAD 2007 will only work
with Visual Studio 2005.
Dan
it support COM?
Thank you.
André Cunha
”Boost
