Hi All,
I want to load my new ribbon on startup. My problem is: I can't get Ribbonservices. Please help me. Thank you.
Solved by kdub_nz. Go to Solution.
Could the issue be that you're not using :
Imports Autodesk.AutoCAD.Ribbon
Ref: (c#)
public static event EventHandler RibbonPaletteSetCreated; |
Declaring Type: | Autodesk.AutoCAD.Ribbon.RibbonServices |
Assembly: | AcWindows, Version=24.2.0.0 |
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
