.NET
Remove One SelectionSet to Another One
3 REPLIES 3
glanard
619 Views, 3 Replies
Assuming the model space is active with a zoom extents, my question is:
I have 2 selection sets:
- ssA= The first one that contains all the entities (SelectAll).
- ssB= The second one that as been made using the SelectCrossingWindow method.
What I want is to remove the 2nd selection set from the first one: in other words, to get (ssA-ssB).
In VBA, I remember we had a RemoveItems method, but it seems not in VB.NET.
Have you an idea to make this substraction?
I repeat that ssB contains SelectedObjectByWindow...
3 REPLIES 3
Hallex
in reply to: glanard
You might want to look closely at FromObjectIds method:
Dim newSset As SelectionSet  = SelectionSet.FromObjectIds(ids)
See docs
~'J'~
glanard
Hi all,
Thanks...
but I found the answer by myself before Smiley Tongue
Something like:
ssA = New ObjectIdCollection(objSS.GetObjectIds())
for each objId As ObjectID in ssB.GetObjectIds()
     ssA.Remove(objId)
next
Hallex
Good point
If this is interesting for somebody else
here is how to apply FromObjectIds method to solve this task
{code}
       <CommandMethod("SELWP")> _
        Public Sub WindowPolygonSelect()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim aset As ObjectIdCollection = Nothing
            Dim bset As List(Of ObjectId) = Nothing
            Dim ppo As New PromptPointOptions(vbLf & "Pick first corner: ")
            Dim res As PromptPointResult
            res = ed.GetPoint(ppo)
            If res.Status <> PromptStatus.OK Then
                Return
            End If
            Dim p1 As Point3d = res.Value
            Dim pco As New PromptCornerOptions(vbLf & "Pick opposite corner: ", p1)
            pco.BasePoint = p1
            pco.UseDashedLine = True
            res = ed.GetCorner(pco)
                Return
            End If
            Dim p2 As Point3d = res.Value
            Try
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    Dim sresA As PromptSelectionResult
                    Dim filterList(,) As Object = New Object(,) {{-4, "<or"}, {0, "text"}, {0, "mtext"}, {0, "dimension"}, {0, "insert"}, {0, "leader"}, {-4, "or>"}}
                    Dim tvs(filterList.GetUpperBound(0)) As TypedValue
                    For i As Integer = 0 To filterList.GetUpperBound(0)
                        tvs(i) = New TypedValue(Convert.ToInt32(filterList(i, 0)), filterList(i, 1))
                    Next
                    Dim filt As SelectionFilter = New SelectionFilter(tvs)
                    sresA = ed.SelectCrossingWindow(p1, p2, filt)
                        Return
                    End If
                    Dim ssA As SelectionSet
                    ssA = sresA.Value
                    If ssA Is Nothing Then
                        ed.WriteMessage(vbLf & "Nothing selected...")
                        Return
                    End If
                    ed.WriteMessage(vbLf & "Selected by crosing window:   {0}", ssA.Count)
                    Dim idsA As ObjectId() = ssA.GetObjectIds
                    aset = New ObjectIdCollection(idsA)
                    Dim sresB As PromptSelectionResult
                    sresB = ed.SelectAll
                    ed.WriteMessage(vbLf & "Selected all:   {0}", sresB.Value.Count)
                    Dim ssB As SelectionSet
                    bset = New List(Of ObjectId)
                    ssB = sresB.Value
                    If ssB Is Nothing Then
                        Return
                    End If
                    Dim idsB As ObjectId() = ssB.GetObjectIds
                    For Each id As ObjectId In idsB
                        If Not aset.Contains(id) Then
                            bset.Add(id)
                        End If
                    Next
                    ssB = SelectionSet.FromObjectIds(bset.ToArray)
                    ed.SetImpliedSelection(ssB)
                    ed.WriteMessage(vbLf & "Now in selection is :   {0}", ssB.Count)
                    tr.Commit()
                End Using
            Catch ex As System.Exception
                MsgBox(ex.Message + vbCrLf + ex.StackTrace)
            Finally
            End Try
        End Sub
{code}
~'J'~
”Boost
