Hallo,
i have an problem with interaction between SendStringToExecute and SetImpliedSelection.
In following example work the SetImpliedSelection fine without the SendStringToExecute,
but with the SendStringToExecute do SetImpliedSelection nothing.
Why??
Code:
[CommandMethod("-SELTEST", CommandFlags.Transparent | CommandFlags.UsePickSet | CommandFlags.Redraw | CommandFlags.Modal)] public void SELTEST() { Autodesk.AutoCAD.EditorInput.Editor acEditor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager. MdiActiveDocument.Editor; Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection acObjectIdCollection; if (acEditor.SelectImplied().Value != null) { Autodesk.AutoCAD.EditorInput.PromptSelectionResult acPromptSelectionResult = acEditor.SelectImplied(); if (acPromptSelectionResult.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK) acObjectIdCollection = new Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection(acPromptSelectionResult.Value.GetObjectIds()); else acObjectIdCollection = new Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection(); // 2 Elements remove from selection for Check acObjectIdCollection.RemoveAt(0); acObjectIdCollection.RemoveAt(0); // ToArray Autodesk.AutoCAD.DatabaseServices.ObjectId[] oIDArray = new Autodesk.AutoCAD.DatabaseServices.ObjectId[acObjectIdCollection.Count]; acObjectIdCollection.CopyTo(oIDArray,0); // SendCommand (without this sendcommand work the SetImpliedSelection fine) Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_zoom _a ", false, false, false); //Set SelectionSet acEditor.SetImpliedSelection(oIDArray); // don't work } }
regards Mario
Actually, the SetImpliedSelection Is working just fine. SendStringToExecute is Asynchronous, so your zoom command runs after the SetImpliedSelection, and clears the selection.
Instead of using SendStringToExecute("_ZOOM _A "); you can use ZoomExtents (or ZoomAll):
public static void ZoomExtents() { object acad = Application.AcadApplication; acad.GetType().InvokeMember("ZoomExtents", BindingFlags.InvokeMethod, null, acad, null); }
public static void ZoomAll() { object acad = Application.AcadApplication; acad.GetType().InvokeMember("ZoomAll", BindingFlags.InvokeMethod, null, acad, null); }
which can be done synchronously with your's code.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Thanks Alexander. I was going to suggest using a graphics system manager to manipulate the view, but it would require that he calculate the extents, which would obviously add a lot of code. I didn't think about invoking a COM call.
Hallo,
for your notes, but the problem is not the "zoom" command. The example code is only a quick and dirty example.
In the Application i select the entities or use the pre-selection and take a user input for "new Elevation"
after this i calulate a new ucs and set the editor.currentucs (or smiliar, just i have no autocad).
Now i calling the "_plan " command to view planar to ucs, '(load "...")' the flatten.lsp with SendCommand.
Then i would like to set the "SetImpliedSelection" with the Objectidcollection from begin of the app and
lastly i calling the "flatten" command. (the origin flatten.lsp i have modify to complete silent)
On debug is set the editor.ImpliedSelection okay but on flatten comes to nothing.
I think ist a effect of the asynchronous for SendStringToExecute.
There is a synchronous variant of SendStringToExecute?
@Alexander:
On next Monday i test the : acad.GetType().InvokeMember for my Application.
until then a nice weekend.
regards Mario
You can wrap the P/Invoked acedCmd in an helper 'Command' method. See here:
http://www.theswamp.org/index.php?topic=31886.msg460020#msg460020
Then use it as the LISP command function:
Command("_.circle", Point3d.Origin, 10.0);
Command("_.move", selSet, Point3d.Origin, new Point3d(10.0, 20.0, 0.0));
Hello Alexander and _gile
the examples of "send synchronously commands" works fine.
But now i have one problem by send command '(load "C:/test.lsp")'.
AutoCAD response "LISP command not available"!?
How can i load the lsp-file?
When i load the lisp-file on appload automatically then don't find AutoCAD
the lispfunction, response "unknown command". But when i input the same
command in the AutoCAD-Commandline then works the command !?
regards Mario
(load...) is not a command. The acedCmd() method only accepts commands and the input they request..
To execute LISP you could use acedEvaluateLisp() or acedInvoke() via P/Invoke.
... i give up ...
Now i have test all variants of send lisp-Command. No variant works for (load "abc.lsp").
And no synchron commandcalling-variant can call a lisp-exported command.
My Solution:
I load the lisp-file over "Appload" and call the lisp-exported function as lasted in my app over "SendStringToExecute".
This works.
i have found in TheSwamp
When .net function set the "CommandFlags.Session" then works the
((Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication).ActiveDocument.SendCommand(commandstring);
Synchronously. And does what i want.
regards ... over and out ...
Mario
