In our drawings we have a layout with a view port and tittle block.
Default printer set for that layout is "dwg to pdf.pc3" and paper is "ISO A3".
I had to plot this layout [extence] to a plt file for the use of our Production ERP.
We had to print to a specific windows printer with paper size A3.
We use to do it in VBA with the bellow code.
How to do it in .Net
Public Function BetsyPlot2() As Boolean
Dim Plot As AcadPlot
Dim alayout As AcadLayout
Dim lowerLeft(0 To 1) As Double
Dim upperRight(0 To 1) As Double
Dim retval As Boolean
retval = flase
For Each alayout In ThisDrawing.layouts
If alayout.Name = "Betsy" Then
RedrawViewPort
ThisDrawing.ActiveLayout = alayout
ThisDrawing.SetVariable "ANNOALLVISIBLE", 1
lowerLeft(0) = 0
lowerLeft(1) = 0
upperRight(0) = 400
upperRight(1) = 275
alayout.SetWindowToPlot lowerLeft, upperRight
alayout.PlotType = acWindow
'alayout.UseStandardScale = True
alayout.StandardScale = acScaleToFit
'ThisDrawing.ActiveLayout.PlotRotation = ac270degrees
alayout.ShowPlotStyles = False 'if it is true this may cause the layout become black & wite
' MsgBox ("sss")
Set Plot = alayout.Document.Plot
' Plot.DisplayPlotPreview acPartialPreview
ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
Call CreateDirectory(Trim(Me.txtFileNo.Text), BasePath)
retval = Plot.PlotToFile(BasePath & Me.txtFileNo.Text & "\" & Me.txtDwgNo.Text & ".plt", comboPlotPrinter.Text)
BetsyPlot2 = retval
Exit Function
End If
Next alayout
MsgBox ("Betsy layout not found in the drawing!")
BetsyPlot2 = retval
End Function
Shijith
Please advice how to plot a layout to a printer & its paper size which is not part of the layout page setup.
All example uses "dwg to pdf.pc3" but in my cas i had to use a system printer.
I just want to print to a system printer with default specification in the printer itself.
Please help.
Shijith
I solved my issue by creating a pc3 file for the printer and passing null to media.
Is there no aother way to specify a network or system printer.
Please advice.
Shijith
