so I implemented the code from the autodesk developers guide for plotting
I made a few minor changes such as making it a sub instead of a command, and commented out a few of the plot settings
the routine seems to work except that I don't get a PDF
I added the actrans.commit() to see fi that might help = nope.
also note that ACF.acdoc & ACF.db in my code replace acdoc & acCurDb in the original code
'<CommandMethod("PlotCurrentLayout")> _ Public Sub PlotMe(suBpath As String, subFileName As String) '' Get the current document and database, and start a transaction 'Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument 'Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = ACF.Db.TransactionManager.StartTransaction() '' Reference the Layout Manager Dim acLayoutMgr As LayoutManager acLayoutMgr = LayoutManager.Current '' Get the current layout and output its name in the Command Line window Dim acLayout As Layout acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForRead) '' Get the PlotInfo from the layout Dim acPlInfo As PlotInfo = New PlotInfo() acPlInfo.Layout = acLayout.ObjectId '' Get a copy of the PlotSettings from the layout Dim acPlSet As PlotSettings = New PlotSettings(acLayout.ModelType) acPlSet.CopyFrom(acLayout) '' Update the PlotSettings object Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current '' Set the plot type 'acPlSetVdr.SetPlotType(acPlSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents) '' Set the plot scale 'acPlSetVdr.SetUseStandardScale(acPlSet, True) ' acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit) '' Center the plot ' acPlSetVdr.SetPlotCentered(acPlSet, True) '' Set the plot device to use 'acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWF6 ePlot.pc3", "ANSI_A_(8.50_x_11.00_Inches)") '' Set the plot info as an override since it will '' not be saved back to the layout acPlInfo.OverrideSettings = acPlSet '' Validate the plot info Dim acPlInfoVdr As PlotInfoValidator = New PlotInfoValidator() acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled acPlInfoVdr.Validate(acPlInfo) '' Check to see if a plot is already in progress If PlotFactory.ProcessPlotState = Autodesk.AutoCAD.PlottingServices.ProcessPlotState.NotPlotting Then Using acPlEng As PlotEngine = PlotFactory.CreatePublishEngine() '' Track the plot progress with a Progress dialog Dim acPlProgDlg As PlotProgressDialog = New PlotProgressDialog(False, 1, True) Using (acPlProgDlg) '' Define the status messages to display when plotting starts acPlProgDlg.PlotMsgString(PlotMessageIndex.DialogTitle) = _ "Plot Progress" acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelJobButtonMessage) = _ "Cancel Job" acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage) = _ "Cancel Sheet" acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetSetProgressCaption) = _ "Sheet Set Progress" acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetProgressCaption) = _ "Sheet Progress" '' Set the plot progress range acPlProgDlg.LowerPlotProgressRange = 0 acPlProgDlg.UpperPlotProgressRange = 100 acPlProgDlg.PlotProgressPos = 0 '' Display the Progress dialog acPlProgDlg.OnBeginPlot() acPlProgDlg.IsVisible = True '' Start to plot the layout acPlEng.BeginPlot(acPlProgDlg, Nothing) '' Define the plot output acPlEng.BeginDocument(acPlInfo, ACF.acDoc.Name, Nothing, 1, True, suBpath & subFileName) '' Display information about the current plot acPlProgDlg.PlotMsgString(PlotMessageIndex.Status) = "Plotting: " & ACF.acDoc.Name & " - " & acLayout.LayoutName '' Set the sheet progress range acPlProgDlg.OnBeginSheet() acPlProgDlg.LowerSheetProgressRange = 0 acPlProgDlg.UpperSheetProgressRange = 100 acPlProgDlg.SheetProgressPos = 0 '' Plot the first sheet/layout Dim acPlPageInfo As PlotPageInfo = New PlotPageInfo() acPlEng.BeginPage(acPlPageInfo, acPlInfo, True, Nothing) acPlEng.BeginGenerateGraphics(Nothing) acPlEng.EndGenerateGraphics(Nothing) '' Finish plotting the sheet/layout acPlEng.EndPage(Nothing) acPlProgDlg.SheetProgressPos = 100 acPlProgDlg.OnEndSheet() '' Finish plotting the document acPlEng.EndDocument(Nothing) '' Finish the plot acPlProgDlg.PlotProgressPos = 100 acPlProgDlg.OnEndPlot() acPlEng.EndPlot(Nothing) End Using End Using End If acTrans.Commit() End Using End Sub
Does the code run through without exception raised (it seems, because you did not mention)? If the code did run through without error, could it be that AutoCAD did output something but you did not notice:
The output is a DWF (because you used "DWF6 ePlot.pc3", not PDF. If your true intention is to plot to PDF, you should use "DWG to PDF.pc3 (or other available PDF plotting device available to the computer). So, if you tried to find *.PDF file in the output folder, you did not see PDF file, thus you thought nothing was plotted. Well, I do not know what output file name you passed in is. Assume it is correct (with *.pdf extention), try again with "Dwg To Pdf.pc3".
Norman Yuan
Facebook | Twitter | LinkedIn
setting background plotting to be off probably helped.
I also need to add a "\" between my file path & file name.
now when i run the code with this:
it works,
but if I change that line to this:
acPlSetVdr.SetPlotConfigurationName(acPlSet, "CutePDF Writer.pc3", "Letter")
it almost works; I get a PLT file instead of a pdf, & yes I do have a pc3 named "CutePDF Writer"
