And this newsgroup is really about using AutoCAD's .NET API, not necessarily
the COM/ActiveX API.
Dan
"Norman Yuan" wrote in message
news:5552751@discussion.autodesk.com...
>This what I can't get --> Autodesk.AutoCAD.ApplicationServices.Application
If you are not using ObjectARX .NET API, you do not get that.
>This is what I want to do --> AcadApp.ShowModalDialog(myForm);
You cannot do that: Acad COM object AcadApplication does not have a method
to show your form as modal/modeless dialog. You need to show your form in
your own code
You may to describe what you want to do and how do you do it (a stand alone
app, or ObjectAXR .NET API app, or COM DLL use for Acad VBA?).
With VB.NET/C#, there are at least two types of Acad programming: COM
Automation/DLL, or ObjectARX .NET API. If you do not indicate what is you
are doing, it is difficult to point out a coorect direction you should be
going.
