.NET
Modify a selected attribute value in a block
5 REPLIES 5
776 Views, 5 Replies
I am trying to modify an attribute value in a block which I can select it on screen. The question is: when selecting the block, if the entity I pick is an attribute part of the block, can I get the attribute's tag? What I am trying to do is to update a revision block, changing one particular value but the attribute's tag it is not the same it can be different from drawing to drawing.
Thanks for your suggestions.
E.G.
5 REPLIES 5
norman.yuan
You can use Editor.GetNestedEntity() to allow user to directly pick an AttributeReference inside a BlockReference. Then update the Attributereference
Norman Yuan
Drive CAD With Code
Yuan,
About the getnestedentity()
My situation:
I'm standing in paperspace. This has one vp.
Can i use the above method to select an entity in the vp wich i've not opend. So i need to select an entity(drawn in modelspace) while standing in paperspace. I need the to get xrecord information so i can automate my annotation.
Hope you understand my problem.
Otherwise please let me know.
Kind regard,
Irvin
in reply to: norman.yuan
Thanks Norman,
it solved my problem.
E.G.
kdub_nz
How ?
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
in reply to: kdub_nz
Here is the sample code(might need some adjusment): whatever text I have in the clipboard I'll paste it into attribute:
    <CommandMethod("44")> _
    Public Sub UpdateAttributeValue()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim rs As PromptNestedEntityResult = ed.GetNestedEntity(vbLf & "Select attribute: ")
        Dim sTemp As String = String.Empty
        sTemp = My.Computer.Clipboard.GetText
        If sTemp = String.Empty Then
            MsgBox("There is no text in clipboard. Please copy some..")
            Return
        End If
        If rs.Status = PromptStatus.OK Then
            Dim oid As ObjectId = rs.ObjectId
            Using tr As Transaction = doc.TransactionManager.StartTransaction()
                Dim ent As Entity = DirectCast(tr.GetObject(oid, OpenMode.ForRead), Entity)
                If TypeOf ent Is AttributeReference Then
                    Dim attref As AttributeReference = DirectCast(ent, AttributeReference)
                    attref.UpgradeOpen()
                    attref.TextString = sTemp
                End If
                tr.Commit()
            End Using
        End If
    End Sub
 E.G.
Forma Design Contest
