.NET
Imports Autodesk.AutoCAD.ApplicationServices
7 REPLIES 7
Message 1 of 8
rmichels
3302 Views, 7 Replies
Why can I not Import this. After I get to Autodesk.AutoCAD, the only thing I can select is Interop.
Help???
7 REPLIES 7
Message 2 of 8
in reply to: rmichels
Just a tip:
If you want help here from your peers, its a good idea to not post anonymously.
Identifing yourself will definitely get you more reponses.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:5997804@discussion.autodesk.com...
Help???
Message 3 of 8
rmichels
What do you mean by posting Anonymously?
Rodney
Message 4 of 8
Not identifying yourself and your professional affiliation.
Message 5 of 8
Have you added references to the acdbmgd and acmgd dlls in your project?
Also (if you do that) make sure that CopyLocal is set to false.
Terry
Message 6 of 8
Change your Target .net framework to 3.5.
Message 7 of 8
sir how do i add reference of acmgd? i am not able to find it in the reference browse menu. what are the libraries that i need to download?
Message 8 of 8
Please have a look in below link. you will find your answer. this is a very old post. In this case you should create a new message.
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS73099cc142f48755f2fc9df120970276f7-535...
”Boost
