How to use acedssget() function(use this function to select by crossing polygon) in autocad development using C# ,thank you!
Solved by Alexander.Rivilis. Go to Solution.
What about Editor.SelectCrossingPolygon method?
Facebook | Twitter | LinkedIn
I want to use acedssget to achive Editor.SelectCrossingPolygon .thank you!
Do I understand correctly that Editor.SelectCrossingPolygon satisfy you?
Do you know that all points passed to the method Editor.SelectCrossingPolygon should be visible on the screen (current viewport)?
