.NET
Hatching for an object
8 REPLIES 8
Message 1 of 9
473 Views, 8 Replies
Hai,
Can any one tell how to use hatching for an object for example a circle
N. siva shanmugam.
8 REPLIES 8
Message 2 of 9
Hai,
To be more precise how fill a color for a circle using hatching.
N. siva shanmugam.
Message 3 of 9
Hai,
Plz provide an example of how to fill a color a circle using hatching.
N. Siva shanmugam.
Message 4 of 9
http://dictionary.reference.com/search?r=2&q=self-importance
gl - Paul
wrote in message news:5126441@discussion.autodesk.com...
Hai,
N. Siva shanmugam.
Message 5 of 9
It is something like this, this should help for the start.
BlockTableRecord btr = (BlockTableRecord)myT.GetObject(db.CurrentSpaceId,
OpenMode.ForWrite, false);
Circle MeasuringPoint = new Circle(InsertPoint, new Vector3d(0, 0, 1),
Radius);
btr.AppendEntity(MeasuringPoint);
myT.AddNewlyCreatedDBObject(MeasuringPoint, true);
ObjectIdCollection IDColl = new ObjectIdCollection();
IDColl.Add(MeasuringPoint.ObjectId);
Hatch MeasuringHatch = new Hatch();
MeasuringHatch.SetHatchPattern(HatchPatternType.PreDefined, "SOLID");
btr.AppendEntity(MeasuringHatch);
myT.AddNewlyCreatedDBObject(MeasuringHatch, true);
MeasuringHatch.Associative = true;
MeasuringHatch.AppendLoop(1, IDColl);
Roland Feletic
schrieb im Newsbeitrag
news:5126398@discussion.autodesk.com...
Hai,
N. siva shanmugam.
Message 6 of 9
Hai,
thanks roland its working fine.
But the hatch and circle is taken as a seperate entity when I move with the help of the mouse, but I need both hatch and circle to act as a same entity.
It mean after creating my program when I move the circle with the help of the mouse the hatch should also be moved simultaneously,
N. Siva shanmugam.
Message 7 of 9
The hatch should be associative. If you move the circle the hatch should
stay in the circle. For me it works.
Roland Feletic
Message 8 of 9
Hai
Thanks for the reply and support...
But when I try your code both the hatch and the circle is taking as a seperate entity. I don't where I am going wrong.
Plz check the below code which is what i tried.
Code:
AcadDb.Circle circleobj = new AcadDb.Circle(new Autodesk.AutoCAD.Geometry.Point3d(30, 10, 0),Autodesk.AutoCAD.Geometry.Vector3d.ZAxis, 5);
AcadDb.Database db = AcadApp.DocumentManager.MdiActiveDocument.Database;
Autodesk.AutoCAD.DatabaseServices.Transaction tm = db.TransactionManager.StartTransaction();
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
try
AcadDb.BlockTable bt = (AcadDb.BlockTable)tm.GetObject(db.BlockTableId,AcadDb.OpenMode.ForRead);
AcadDb.BlockTableRecord btr = (AcadDb.BlockTableRecord)tm.GetObject(AcadDb.HostApplicationServices.WorkingDatabase.CurrentSpaceId,AcadDb.OpenMode.ForWrite);
btr.AppendEntity(circleobj);
tm.AddNewlyCreatedDBObject(circleobj,true);
AcadDb.Hatch hatch = new Autodesk.AutoCAD.DatabaseServices.Hatch();
AcadDb.ObjectIdCollection objcol = new Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection ();
objcol.Add(circleobj.ObjectId);
hatch.SetHatchPattern(AcadDb.HatchPatternType.PreDefined, "SOLID");
hatch.ColorIndex = 4;
btr.AppendEntity(hatch);
tm.AddNewlyCreatedDBObject(hatch,true);
hatch.Associative = true;
hatch.AppendLoop(1,objcol);
tm.Commit();
catch(Exception ex)
throw ex;
finally
tm.Dispose();
Thank you,
N. siva shanmugam.
Message 9 of 9
Hi
Can anyone expand on this and demonstrate the more complex case of a polygon (or more) within a polygon, where the inner ones are not filled
Tks
Thiss
”Boost
