.NET
Extracting Layer Attributes
6 REPLIES 6
692 Views, 6 Replies
Hi Group..!!
I am doing one application for autocad designers using VB.Net. In the application we can select one dwg file and extracting the layers inside the drawing..! i did that..but there is one problem. If i clicked on a layer, all layers attributes which is present on the dwg will be extracting... i need one by one depends on the selection of layer.
Can u help me..
6 REPLIES 6
HI,
I did not understand completely your requirement.. Do you want to click the layer from layer manager? if so there is already those attribute. Or if something like that you want to click an entity then it will show in which layer that entitiy is and then shows the layer details then you have to code it and get the layer attribute from its layer table record properties. if so you can start from below code snippet. If I understand wrong then please describe more clearly what do you want to meet your requirement. you can also use picture how do you want .
  Public Sub LayerAttribute()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Using tx As Transaction = db.TransactionManager.StartTransaction()
            Dim lt As LayerTable = tx.GetObject(db.LayerTableId, OpenMode.ForRead)
            For Each id As ObjectId In lt
                Dim ltr As LayerTableRecord = tx.GetObject(id, OpenMode.ForRead)
                'layer name
                Dim lName As String = ltr.Name
                'layer on or off
                Dim lStatus As Boolean = ltr.IsOff
                'layer color
                Dim lcolor As Color = ltr.Color
            Next
        End Using
    End Sub
Hallex
Start with this:
        public void SelectBlocksByLayerFilter()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptNestedEntityResult atres = ed.GetNestedEntity("\nSelect attribute ");
            if (atres.Status != PromptStatus.OK)
                return;
            ObjectId[] nestIds = atres.GetContainers();
            if (nestIds.Length == 0)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockReference br = (BlockReference)tr.GetObject(nestIds[0], OpenMode.ForRead);
                string blockName = br.Name;
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                TypedValue[] tv = new TypedValue[] {
                    new TypedValue((int)DxfCode.Start, "insert"),
                    new TypedValue((int)DxfCode.BlockName, blockName),
                    new TypedValue(66, 1), new TypedValue((int)DxfCode.LayerName, br.Layer)
                SelectionFilter flt = new SelectionFilter(tv);
                PromptSelectionResult resSel = ed.SelectAll(flt);
                SelectionSet selSet = resSel.Value;
                ObjectId[] ids = selSet.GetObjectIds();
                ed.SetImpliedSelection(ids);
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("found: " + ids.Length + " blocks\n on layer:" + br.Layer);
                //    // rest your code here    //  //
                tr.Commit();
 Or VB.NET
		Public Sub SelectBlocksByLayerFilter()
			Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
			Dim ed As Editor = doc.Editor
			Dim atres As PromptNestedEntityResult = ed.GetNestedEntity(vbLf & "Select attribute ")
			If atres.Status <> PromptStatus.OK Then
				Return
			End If
			Dim nestIds As ObjectId() = atres.GetContainers()
			If nestIds.Length = 0 Then
				Return
			End If
			Using tr As Transaction = db.TransactionManager.StartTransaction()
				Dim br As BlockReference = DirectCast(tr.GetObject(nestIds(0), OpenMode.ForRead), BlockReference)
				Dim blockName As String = br.Name
				Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
				Dim tv As TypedValue() = New TypedValue() {New TypedValue(CInt(DxfCode.Start), "insert"), New TypedValue(CInt(DxfCode.BlockName), blockName), New TypedValue(66, 1), New TypedValue(CInt(DxfCode.LayerName), br.Layer)}
				Dim flt As New SelectionFilter(tv)
				Dim resSel As PromptSelectionResult = ed.SelectAll(flt)
				Dim selSet As SelectionSet = resSel.Value
				Dim ids As ObjectId() = selSet.GetObjectIds()
				Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(("found: " + ids.Length & " blocks" & vbLf & " on layer:") + br.Layer)
				'    // rest your code here    //  //
				tr.Commit()
			End Using
		End Sub
 If you need select by attribute layer then change in layer filter instead of br.Layer
put attres.ObjectId.Layer
Hi, Yes i want the layer attribute from layer table records and should be
stored in an excel file in the name of the layer which is selected.
Hallex
Check this out:
http://www.dotsoft.com/freestuff.htm
scroll down to 'LAYERREP.zip'
in reply to: Hallex
thank u...its very helpful..!!
”Boost
