I have seen the sample code in the help documentation that shows how to extend existing PnPTables by relating them to related external/linked databases but I didn't know if it was an acceptable solution for me to just customize the existing AutoDesk PnPTables with custom columnns directly to get those columns to show up in the Data Manager. So, for instance, If I simply add a new column to the 'EngineeringItems' PnP table, am I asking for trouble or is that a common practice? I can certainly make my own PnPTable that simply has a PnPID column and my custom properties and relate that to the 'EngineeringItems' table, as well, but that is a little more work (however, more robust).
Anyone ventured down this path before and have any lessons learned?
thank you
jess
