Error While opening autocad using process.start
Error:
Activation context generation failed for "E:\SI\ProArc\Main\Source\Engineering Client\Source\AutoCAD 2012\SI.Integrations.Engg.AutoCAD2012\AutoCAD 2012 - English\acad.exe". Dependent Assembly PPClientAssembly,processorArchitecture="x86",type="x64",version="2008.1.17012.4817" could not be found. Please use sxstrace.exe for detailed diagnosis.
Please help me on this issue
Raman
Solved by Mike.Wohletz. Go to Solution.
Please post your code on how you are doing the process.start.
Any reason why you would use this method to start AutoCAD?
Just i am clicking on acad.exe and i am getting above error.
and In Event Viewer It is showing as
Raman
It looks to me like you are trying to start the Acad.exe from a location other than where it was installed. I think you should be starting this from the AutoCAD subdirectory in C:\Program Files\Autodesk unless you have installed this in some other location.
I don't think that your issue is related to this post as this is dealing with starting AutoCAD from a custom application. Please review the artical in the included link and see if that solves your problem. If not please post a new thread or find one related.
