.NET
790 Views, 5 Replies
DXperience
How do i get rid of the dxperience tools from the Vault Browser Sample code C#
J.dxperience
5 REPLIES 5
Keith.Brown
did you try removing all references to their libraries?
Thank you for the reply
What's is a quick way to find DXperience references in the Sample Vault Browser project c#
Thanks again.
J.
Keith.Brown
I am not sure what IDE you are using but in visual studio you should be able to see any references in the solution explorer.
I am not sure about other IDE's.
That's what I would expect to find. But I don't see any references. Any other places I should look? I do see DXperience dll files in the projects debug folder.
J.
wayne.brill
Hello J,
This blog post discusses DevExpress and the Vault 2014 SDK:
http://justonesandzeros.typepad.com/blog/2013/05/devexpress-dlls.html
Here is an exceprt about the DevExpress dlls:
The DevExpress DLLs in the Vault SDK (these are the ones in the bin folder that start with “DevExpress”)
I am getting that dialog about "expired version of DXperience Subscription" when I open the VaultBrowserSample.  If I dismiss it I am able to build and run the sample. Do you get the same behavior? I believe it is ok to ignore it and I have never seen that message when the exe is running.
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Forma Design Contest
