.NET
Convert string to ObjectId
7 REPLIES 7
Message 1 of 8
9087 Views, 7 Replies
Hello!
It is possible to convert an ObjectId into a string. But is it also possible to convert a string/int into an ObjectId?
I want to save some ObjectIDs to a text-file to use them later.
But I haven't found something to convert them back.
7 REPLIES 7
Message 2 of 8
Hi!
I found a solution for this problem. I use the Handle instead of the ObjectID-string:
string oldHandle = ent.ObjectId.Handle.Value.ToString();
ObjectId newObjectId = db.GetObjectId(false, new Handle(Convert.ToInt64(oldHandle)), 0);
It works perfect!
Message 3 of 8
This will only work "perfect" as long as there are no alpha characters in the string. It is really a hex number string, but Convert.ToInt64 is treating it as though it were a decimal number string. That will work until you get into the "A,B,C,D,E of F" character(s) of a hex handle string. I could not find a .NET function that would convert a hex string to decimal integer, so I had to write my own. It is not too difficult.
Message 4 of 8
chiefbraincloud
That is not quite true. There is no need to 'write your own' hex translator, just to use the proper overload of the ToInt64 function. There is a version which accepts an argument to specify the base that you are translating from, which works fine with alphanumerics.
ToInt64(ByVal value As String, ByVal fromBase As Integer) As Long
Member of: System.Convert
ObjectId newObjectId = db.GetObjectId(false, new Handle(Convert.ToInt64(oldHandle, 16)), 0);
The only way this fails is if the DBObject referred to by the Handle is no longer in the drawing.
Message 5 of 8
Convert a string representation of a number in hex notation to an Int64:
Int64 result = Int64.Parse( "12AFE", NumberStyles.AllowHexSpecifier );
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6203162@discussion.autodesk.com...
Message 6 of 8
And for those using VS2008:
public static class DatabaseExtensionMethods
public static ObjectId GetObjectId( this Database db, string handle )
return db.GetObjectId( false,
new Handle(
Int64.Parse(handle, NumberStyles.AllowHexSpecifier )));
"Tony Tanzillo" wrote in message
news:6203664@discussion.autodesk.com...
Message 7 of 8
string objIdStr = someObj.ObjectId.Tostring();//after this code objIdStr = "(1234)", where  1234 - id of the object.
string pureObjId = objectId.Trim(new char []{ '(', ')'});//removes '(' and ')'. it's need to convert this string to int
 ObjectId objId = new ObjectId(Convert.ToInt32(pureObjId));//create ObjectId with defined id
Message 8 of 8
public static ObjectId GetObjectId(this Database db, string handle) {
Handle h = new Handle(Int64.Parse(handle, NumberStyles.AllowHexSpecifier));
ObjectId id = ObjectId.Null;
db.TryGetObjectId(h, out id);//TryGetObjectId method
return id;
Forma Design Contest
